Question about Waring WMK300 Professional Belgian Waffle Maker
Waring Pro Belgian waffle maker, fell apart
Unhappy with my Waring Pro Belgian Waffle maker because on the left side where it flips, the whole thing just fell apart.The screw hole evidently melted or just wore out and it just fell apart. This is the second on we have had. The first unit just stopped. I am just sick about this unit. Jan
SOURCE: Belgian Waffle Maker Problem
Receipt not needed - 1 year warranty from Waring, they will replace the entire unit.
Posted on Mar 03, 2008
SOURCE: Waring WMK300 professional Belgian waffle maker
Your thermal cut-out went bad, needs to be replaced.
Posted on Mar 18, 2008
Jerseybob
  • 11 Answers
SOURCE: Waring pro waffle maker
I personnally just went through this.
If it is less than one year old, and you have the receipt, go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
My replacement had a silver body virsus the original black body. The shop told me they have yet had a customer repeat of this problem.
Posted on Apr 02, 2008
  • 5 Answers
SOURCE: Waring Pro Waffle maker
Just spray the grids before each use with something like Pam, or put a thin coat of oil on them. I found it's better to spray before each waffle so it won't stick.
Posted on Mar 09, 2009
  • 5 Answers
Here is what is happening, and if you're out of warranty and so inclined how to easily fix it yourself.
Make sure you are unplugged from the wall before doing anything or you will get shocked. You do not need to take the bottom cover off the base. You do not need to take the top plate apart (they super glued one screw in the top plate (lid), you'll strip out the screw head trying to remove it anyhow). All you need to open is the bottom plate, it has 4 screws in it you will see when you open the lid, these screws are not super glued and will come out. 2 on each side in the back, 2 in the center of the front, long screws go in the back, short in the front.
There are 2 white wires, 1 black wire, 1 green wire that run up the neck of the waffle maker to heat the top and bottom heating elements. The 2 white wires are neutral, the green wire is a ground, the black wire is power.
This black wire runs from the electronic control board in the base of the unit, up the neck in the rear, through a thermal fuse, to the bottom element then jumps up to the top element. All you need to take apart is the bottom plate, the part you pour the batter into. It has 4 screws you will see when you open the top plate up, take those out and you are going to find the black wire is covered by a white rubber like tube about 3 inches long. In the center of this rubber insulation there is a metal clip with a single screw. Take that screw out, pull off the metal clip and slide (don't cut) the rubber like insulation back.
You will find the black wire is crimped onto a silver metal bullet looking component. This component is called a "thermal fuse", its designed to fail at 240 degrees C. Its obviously a design flaw and the thermal fuse is under rated for the actual heat within the device. Its also a one shot fuse, so when it blows it kills power on the black wire from going to the top and bottom plates, thus no heat. It is not resettable.
I didn't even cut mine out (Waring is very skimpy with their wire, they don't leave you even a hint of extra wire to work with). I just tightly twisted the bare metal wire on each side of this component like a bread tie leaving the blown fuse in place. Then be sure to slide the rubber like insulation back over all of the bare metal so it is covering the black wire on both sides. If you don't it will short out and blow your house circuit breaker when you turn it on.
This thermal fuse was probably a requirement of the UL Listing. Its over kill, everything in there is metal so if it over heats in that area there is nothing flammable to burn. If a run away temperature occurs the wire itself will melt, short out and trip your house breaker. There are stacks of these units brand new with this same problem anyone reading this is having, the thermal fuse is under rated, the fix is simple.
Posted on Mar 11, 2009
Diagram to replace thermal fuse in wmk 300 waring pro
The most common reason for thermal fuse failure is running the iron with the top open, especially when set to a higher number (longer cycle time) and/or not flipping the iron over at the strart of a cycle.
Keep it closed except during the 10-15 seconds needed when adding the batter or removing a waffle.
Thermal fuse 240C often available on ebay 4/$2 or Amazon 10/$7-$10
Feb 15, 2014 | Waring WMK300 Professional Belgian Waffle...
I have a wwm200sa waring pro prof belgian waffle maker that will not get hot. The power light will come on but it will not get hot. Why?
HELP WWM200SA IS WAY TO HOT I HAVE IT DOWN TO 1 1/2 STILL ALMOST BURNED CAN SOMEONE HELP ME THANK YOU VICKY
Aug 02, 2011 | Waring Pro WWM200 Waffle Maker
Screws that hold bottom and top together have come out - appears that plastic that they screw into has melted
I repaired the broken "clamshell" of my Waring Pro WMK300 Professional Belgium Waffle Maker by replacing the original screws with a pair of (black metal) #8 x 1.125 inch flat-head machine screws and anti-vibration lock-nuts. These nuts have a nylon insert to prevent loosening. The assembly is now strong enough to pick up by the handle.
I drilled into the original plastic pits to create through-holes. I chose screws just long enough to fill the anti-vibration lock-nuts without protruding. You will need to hold each nut with a wrench or pliers while turning the screw into the nylon of the nut. Tighten just until the waffle iron assembly is snug, then another 1/8 turn. The torque should increase only during this last step.
The nuts are visible when I flip the iron, but I don't mind - they just remind me that the iron is now stronger than factory design.
Feb 23, 2010 | Waring WMK300 Professional Belgian Waffle...
Waring Pro Waffle Maker
Had same issue,found a looks like diode on the black wire leading to the heating elements.It is open circuited.Needs replacing.It is not a diode...maybe a voltage circuit protection device.It is crimped into the black wire under the sleeve clamped down near the handle.Going to radio shack to get a idea,replacement.
Jun 02, 2009 | Waring WMK300 Professional Belgian Waffle...
How do I season my Waring pro Waffle Maker?
Teflon coating does not to be seasoning , but you will need to use a spray shorting like PAM before you make each waffle
Feb 21, 2009 | Waring WMK300 Professional Belgian Waffle...
Falling Apart
your stuck . thats the most common problem with this unit , who would think of plastic that close to a hot element and NO PARTS MADE ......... and waring does not care at all ......... the only thing you can do is google "waring waffle reviews"
. and write reviews about what happend to yours and hope you can help someone else that is thinking about getting the appliance
Nov 07, 2008 | Waring WMK300 Professional Belgian Waffle...
Waring WMK300 Professional Belgian Waffle Maker Logo
81 people viewed this question
Top Waring Kitchen Appliances - Others Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
