Question about Thermador 30", 36", 42", 48", 60" Wall Hoods, PHE
I have the thermador 36 hood that just stopped working. Neither the blower or the lights work. I check the circuit breaker to make sure it was in the on position
5 Suggested Answers
manhandy
  • 146 Answers
SOURCE: My Thermador hood PH48ZS stopped working ....was on...stopped.
are you getting power to the unite? if you are then probably the switch.
Posted on Jun 24, 2009
  • 106 Answers
SOURCE: the bottom heating element is not working on my thermador prgs/36
one of 3 things may of happed. 1, the element may have burned out. (you will see a blister or burn through on surface of element. 2 the wires that go to the element may have burned off. 3 the power relay board is not sending power to the element. (bad board or fans sail switch NG)All things need to be checked with 220v power off to the range. I would recomend calling a local pro.
Posted on Oct 30, 2009
Testimonial: "thanks so much for the info.this narrows my problem."
  • 101 Answers
SOURCE: No power to the fan or lights. Checked the
You're saying fan (singular) and lights (plural)? Does this fan and these lights work off of one switch? If so, then it's probably a bad switch. You can check this by turning off the circuit breaker. Remove the switch from the wall, and put the two wires going to that switch together. Make sure to use a wire nut, or tape to keep these wires together without touching and grounding anything. Make sure these wires are clear of anyone or anything, and then go back and turn on the circuit breaker. If the lights and fan go back on, then it's a bad switch. This is what it sounds like. So now, you can turn the cir. brkr back off - replace the switch, and then after everything is secure and the switch is in the off position - you can turn the cir. brkr back on again. Then go back into the kitchen and turn the switch on again to reaffirm that everything is back in working order. If for some reason this doesn't work, feel free to contact me again. Good Luck!  Jim
Posted on Mar 30, 2010
SOURCE: Fan light flashing on thermador vent hood model HNW36YS
Grease Filter Saturation LED The speed 2 LED in Figure 1 in is marked with an F. This LED will flash to remind you when the grease filter needs to be cleaned after 40 hours use. Follow the instructions for cleaning filters in thisFollow the instructions for cleaning filters in this booklet. Once the grease filters have been cleaned, reset the display by pressing button A for
Posted on Jul 25, 2010
Ge zv850 vent hood
was this a d.i.y. project, if so was a proper ground ran from breaker usually a size bigger than the power. when the fan goes out does the light do the same, as u may have crossed your device wires. electrical can be tricky because there can be several reasons for your issue. u suggest u double check your work ensuring everything is
Feb 17, 2014 | Kitchen Ranges
Thermador cooknvent downdraft CVS36R
this is the little circuit board in the switch that is defective here you will eed to replace it.
Oct 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador CVS36R Cook'n'vent vent won't go down and fan stopped workin
You probably will find that the vent is clogged with grease. A switch device works with the vent so the fan operates only when the vent is open and does not operate when the vent is closed. Things should get back to normal after a thorough cleaning unless the fan is defective and won't operate at all.
Sep 03, 2012 | Thermador CVS236 36" Cook 'n' Vent System...
Mar 30, 2010 | Thermador 30", 36", 42", 48", 60" Wall...
Thermador Downdraft blower Fan Not Working
could have serveral problems / if under counter or in back of range . the last two i had the control buttons w wire harness needed replacement /another required the pc board in connevtion box ( under counter in right cornor. also look for poor connections in the power box .
Dec 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Switch to operate the blower unit works sometimes
i am not sure if they will have your part but you can try universal appliance parts store...if you google it you will find one in your area...
Feb 16, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Downdraft blower quit working
replace whole unit thats roughly what the whole unit costs 157.00 just a little secret there they dont tell you cause they mark up the prices i worked for the company that sold and installed this equipment you also remember tax
Jun 01, 2008 | Kenmore 59940 Kitchen Hood
Thermador 30", 36", 42", 48", 60" Wall Hoods, PHE Logo
24 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
