Question about Kirby Heritage II Vacuum
My Kirby 2HD has started making an odd roaring noise but still works fine. I have taken the front assembly off and cleaned and adjusted the roller and checked the belt. The noise seems to come from the motor housing. I have tried to wiggle the main shaft at the front (bearings?) and it seems tight. Can't seem to get the other housings apart. Any ideas? Thanks, John
  • yukon_joh184 Oct 06, 2009
    Using a flashlight, slowly rotate the impeller by hand and inspect for damage (broken fins, cracks,etc.) This usually causes a different sound when the motor is running.
    President:
  • 2,976 Answers
It is quite possible, it just needs lubed. The motor comes in direct contact with dirt so, you have to make sure the front bearing has a drop of oil on it from time to time. If it starts to scream at you within one month, after oiling, the bearing needs to be replaced.
Posted on Oct 05, 2009
Testimonial: "I will try that upon reassembly. In the meantime, I discovered a blade broken off the impeller which is probably the culprit but thanks for your idea."
  • David Shaub Oct 06, 2009
    Since you have a broken impellor, it will need to be replaced. Being unbalanced will burn out the bearing directly behind it.
Kirby works with the brush roller head; but not the hose attachment (won't start with hose attachment)
The part of the hose that attaches to the vacuum should push on the switch on the front of the vacuum so it won't come on without the nozzle or hose attached. Inspect the hose to see if that part may be broken or not making good contact to activate the switch,
Feb 26, 2018 | Kirby Vacuums
Hi, my kirby makes a very loud and rattly noise when im vacuming, and sometimes the roller brush stops working, please help thank you
replace fan,belt and either clean ends of rollerbrush of string, hair, floss, etc or buy a new rollerbrush
Dec 08, 2010 | Kirby G5 Bagged Upright Vacuum
Looking for a manual for a kirby Heritage 11 modle 2HD
Hello
I did a search and found a very useful web site for owners of the same vaccum as yours im sure you will be able to get parts and possibly a manual, hope it helps
http://kirby-owners-club-shop.com/
Jul 23, 2009 | Kirby G6 Bagged Upright Vacuum
Old Kirby Heritage 2 (Model 2Hd ) won't power on
the power light is a 2 stepswitch make sure when u put yhe power head back on it is locking all the way back if so and not working the switch may have failed
Jul 10, 2009 | Kirby Vacuums
Kirby legend 11
Just got done fixing our Heritage II model 2HD, it had a dirty safety switch. Both the hose attachment and the roller housing depress a plunger to close the switch, thus sending AC to the motor brushes. You might want to try pushing this in and out repeatedly with your thumb, power removed of course, in an attempt to make better contact. If this works to restore power to the motor, it'll be just a short time before the problem repeats itself. You'll have to remove the switch to give it a thorough cleaning. I didn't have any contact cleaner handy, so I wound up using WD40. Hope this helps. Kevin H.
Apr 04, 2009 | Kirby Heritage II Vacuum
Fuse for Kirby vacuum
I would take it into a local vacuum shop but DONT take it to a kirby shop because they will charge way more
Apr 13, 2008 | Kirby Heritage II Vacuum
Kirby 2hd how do i put the belt on this vacuum thanks
On the Front of sweeper is a Tab Turn it and it will release the Beater Bar assembely Put the Belt around the Bar and put the Belt on the inner tab Turn and the Belt should go around motor Good luck ttech
Jul 24, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums Logo
201 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
