Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
I can't find my service manual and I'm trying to set the tv channels in memory?
    Sniper:
  • 77 Answers
,Hi buddy,
You can get your manual from here
http://www.fixya.com/support/p216782-sharp_aquos_lc_32g4u_32_in_hdtv_ready/manual-5423
I hope this will help you out. PLZ VOte for me.
Thanks
Posted on Oct 05, 2009
Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
Dec 17, 2012 | Vizio RazorLED M260VA 26" LED-LCD TV -...
My Technika TV model X22/14C-GW-TCD-UK loses all of its channels when I turn it off. I have to retune everytime I turn the TV back on, Any Ideas welcome, many thanks
All sets use a eprom in some form or another that stores the memory of what up/down channels are programmed into the memory of the set-I will presume no box is used in line with this set for signal---very rare for this problem to even happen---next try when turn on to direct enter a known channel and see if set goes there--then manually add it in the menu---if set does not lose that memory at worst you can manually add every channel one at a time.
Oct 30, 2012 | Televison & Video
Sony KV-32FS120 32" TV Will not stay on a TV channel
It sounds that the main system memory IC of your set has either damaged or confused. Just make a factory reset. If this do not help you, replace the memory IC
Apr 30, 2012 | Sony Televison & Video
I am trying to get the tv to go to channel 116 so it will work with my satelite but it will only go to channel 99
Hello
The channel may have been erased from the channel memory by the ADD/ERASE feature. Add
the channel to the channel memory
To get the erased channels back to; you have to do it manually.
Enter its 'Menu" and come to "Set Up"
Press [UP] or [Down} buttons on the remote control to select and hilight [ADD/ERASE]
Press [>] of [<] buttons on the remote to select ADD or ERASE, depending on the function you want to perform.
NB: If you cannot get this function activated with your TV, make sure that the system memory IC on the circuit board of your tV is faulty, and should be replaced with same type and number. Actually it is a very skilled work, and must be done by any well experienced service techinician or by the Authorised Service Center for Toashiba at your town. OK
gopakumarg43
Oct 01, 2011 | Toshiba 32AFX54 TV
Please program channel memory and all channels are unavailable I have fios so I only need channel 3
U still have the tv original remote?Yes,must used it to get into chanel 3.Because the manual buttons channels up and down on the tv bazel frame will skip channel 3.Only able get into channel 3 by manual channel buttons up or down only if it was save in the tv memory.Try website like Remotes.com to buy the tv original remote.
Jun 07, 2011 | Philips Magnavox 27MS343S 27" TV
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I can't manually setup the Channels on my Panasonic PV 9451 VCR
In the Menu go to manual channel set-up not auto. When you're in manual set-up change channels until you get to to L-1 and L-2 (should be below Ch 2) and save both to memory. On some TV's the L-1 and L-2 are selected with a separate button labeled "input".
Aug 15, 2009 | Panasonic Televison & Video
Sanyo Flat screen
try to check the settings of your tv if all ok. if ok its a problem in your TV circuit board try to resolder maybe some sections is cold solder. if not its a service mode. trust me!
May 20, 2009 | Sanyo DP26648-R 26 in. LCD TV
We are receiving channels 1-13 only; don't know how to add more
make sure you have your tv set to cable, if you have a set top box unplug the box plug it back in reboot it, like i said make sure your tv is set to cable then do auto channel scan should work good luck!!
Apr 12, 2009 | Toshiba MD20Q41 20 in. TV/DVD Combo
Channel Memory Not working
I can help with two solutions, if you wish.Please verify Model
# and mo / yr built off back of set.............T.
Aug 23, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
90 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
