Question about Dell Inspiron 1501 Notebook
I have a 500Gb external hard drive (seagate freeagent desk). I am using a dell inspiron 1501 laptop. I attempted to copy a large amount of files to my hard drive but the process failed. Now, i keep getting a $mft error saying the files did not copy over, please try and copy them elsewhere. The big problem is that i reformated my laptop harddrive and no longer have the files (nothing too important lost). But now with the newly formated laptop (and yes, there is an ATI driver used), i can't seem to wipe out the memory of those files on the external drive. I also get an i/o error when trying to copy some of the files off of the external drive. Any ideas?
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 05, 2009
  • 153 Answers
Try using your ext hdd in other system desktop
wethere it is working fine or not...
go to start>run
type
chkdsk the drive: (eg.if ext hdd drive is h:) and press enter
(eg. "chkdsk h:" )
see for any error dispsplay
proceed accordingly
I USED MY FREE AGENT DESK EXTERNAL DRIVE 500GB ON MY MAC GOT A NEW DELL AND CONNECTED THE DRIVE...IT SHOWS UP BUT I CANNOT OPEN IT PLEASE HELP
if you still can see files on the Hard disk from MAC, then the reason of being unabe to explore your file from MS windows is that your hard was initialized by MAC with a format that windows cannot read.
move your data from external hard disk to your MAC then format your hard disk from windows OS with FAT32 format .this format is readable on both MAC and WINDOWS
Jun 30, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Freeagent 500gb not responsive. No lights; just a beeping noise.
ok here goes, my neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 hope this helps Ytee.
Good Luck
Aug 15, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My seagate 320 GB drive is flashing white....computer does not recognize it. Help...
ok here goes, my neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 hope this helps Ytee. GL
Seagate free agent external drive not getting detected
Aug 12, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have just purchased a Seagate 500GB Desktop hard drive
There is software preloaded on the disk. If you have AutoPlay turned off in your system, it won't start automatically when you connect the drive. Just go to MyComputer and open the drive and you will find a setup file there to install the backup software (I think it's called Launch.exe).
Oct 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Desk - "Drive cannot be modified"
I went into Disc Utility and partitioned the whole drive for Mac OSX. After that was done, I was able to write to the drive and copy over files.
Nov 29, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
No Power to my Seagate FreeAgent Pro 500GB
I think you screw yourself... you have just burn your files
Sep 24, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate freeagent 500g usb 2.0 beeps sound
You still need assistance in cracking open the Seagate Freeagent Pro 500GB and trying data/file recovery? If yes, would appreciate a post back.
Good luck and kind regards.
Thank you for using FixYa.
Mar 17, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Dell Inspiron 1501 Notebook Logo
106 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
