Question about Vehicle Parts & Accessories
Cant start my car up with key key symoble on dash flashing
    Problem Solver:
  • 5 Answers
The key probably lost its codes you might need to make a trip to the dealer which will not be cheap
Posted on Oct 09, 2009
Why is key sign flashing on dash when engine is on 2001 honda civic ex
battery low on keyfob ? as it cant be anything with antitheft or it wouldn't let you drive it away
Mar 10, 2016 | 2001 Honda Civic 1.7
My ignition turns but will not start car
its def still your anti theft.. I had the same problem in my buick. I fixed mine myself there is a part u can get.. I haven't had an issue since and its been 4 years.. check it out
Oct 14, 2014 | 2005 Pontiac Grand Am
My 1995 Jeep Grand Cherokee Laredo wont start and has blue security light flashing
Did u try unlocking the passenger door with the key?these are very common for the drivers switch goin bad
Apr 19, 2013 | 1995 Jeep Grand Cherokee
Flashing red dot on my dash for 2002 caravan and wont start
It sounds like the car is not recognizing the key. That red light is the anti-theft indicator. Sometimes due to batteries dying in the key fob or car itself this can happen. The car and key essentially loose track of each other. It can also be a problem with the vehicles control module. This is a situation where you are pretty much stuck with taking it to a Dodge dealership where they can hook it to a scan tool or reprogram a key, depending on what the exact issue is.
Nov 17, 2012 | 2005 Dodge Caravan
The warning lamp for the electronic immobiliser flashes continuously for the audi and it cant start. This started after we struggled to get the new battery in
Whenever this warning or any other stays on in the dash it is indicating that the systems control module has detected a fault, it then disables the system as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Sep 27, 2012 | 1996 Audi A4
Key fob would not open 1995 discovery ,used key in door then alarm went off ,after a few seconds alarm ceased then put key in to start engine and got nothing now cant lock doors with key but red light is...
The red light means the Immobiliser has not been turned off, the deactivator in the key must not be working correctly, visit your local land rover dealer who will be able to make sure the key is paired to the car correctly, otherwise you may need a new key.
Feb 11, 2011 | 1995 Land Rover Discovery
The immoboliser light flashes when the key is turned?
this is how the immobiliser system works........you have a remote,it has 2 codes,one is fixed,one is random,the random code changes every time you lock the car,and this is the code the car reccognises to open/start the car.the fixed code is for simple key reccognition.the key has a magnet inbuilt that has a fixed code that matches the remotes fixed code.if you use a wrong key,the car will start,then die.the flashing light on the dash is a warning that the key code is weak and COULD cause a malfunction.use your spare keys and if the light still flashes you may need to have the keys recoded.(NO. YOU CANT DO THEM YOURSELF as the VW computer diagnostic computer has to match then reccognise the key to the car.) thats why when reseting the keys/car after a battery is changed you must go through the set/reset as shown in the handbook(that nobody seems to own).
Nov 22, 2010 | 1997 Audi A4
Cant start. the power to the dash stays on even
Sounds like a bad starter switch at the column there. May need to replace that.
Mar 16, 2010 | 2001 Ford Taurus
No keys
If you want to initiate a new master key.... 1. Insert new key into ignition cylinder and turn it to the ON (RUN) position. The security light on the dash will flash for fifteen minutes.
2. When the security light stops flashing, you have FIVE minutes to start the next step. Turn the ignition cylinder OFF and then back to the ON (RUN) position. The security light on the dash will flash for fifteen more minutes.
3. When the security light stops flashing, you have FIVE minutes to start the next step. Turn the ignition cylinder to OFF and then back ON (RUN) position. The dash will flash for fifteen more minutes.
4. After the security light stops flashing the third time, the new key has been programmed into the vehicles computer and will operate the car. It has replaced ALL the previous electronic key codes and is the ONLY key programmed into the vehicles computer.
The dealership should be able to do this for you without a current key, of course this means towing the vehicle to them. See if they will sell you a key and you program it yourself.
hope this helps. I found the above info at FordF150.net
Jun 22, 2009 | 1998 Ford Contour
Vw jetta wont let me start it
It's an ignition problem. If you keep trying to turn over it will start. It's an anti theft device they installed. The little car with the flashing key. Someone likely tampered with your ignition before for this to happen.
Feb 07, 2009 | 2000 Volkswagen Jetta TDI
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
