Question about Whirlpool Duet GHW9150P Front Load Washer
The F35 signal is still showing on our washing machine. We checked the drain from the machine to the wall. It is clear. We took out all the clothes and ran the water seemed to be ok and then the Sud signal came on. We did the rinse cycle and it is back to the F35. We did remove a small tiny toy from where the drain inside the washer is in the beginning of this process.
    President:
  • 1,653 Answers
To cure the F35 with the occasional SUD fault showing in the display the problem means that you need to unplug the machine from the mains and turn off the water supply. Then remove the lower cover, looking at it from the front where the glass door is, so you can see the water pump. On the water pump there is a round cover, turn it counter clockwise to get it loose, then the the filter will come out. You may find some interesting things in there! Clean it and screw it back on. Make sure the machine is powered off at the mains for 30 minutes in total to reset the computer and clear the fault display. Reconnect the mains power and turn the water supply back on. The machine should now operate correctly.
Posted on Oct 05, 2009
Whirlpool duet f35 error-suds error
Maybe this will help, but I'm not sure
Condition:
SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Check:
If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked.
Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
Check/Clean Drain Pump Filter of foreign objects
Check Drain Pump
Check Pressure Switch
Check CCU
Dado
Sep 13, 2015 | Whirlpool Washing Machines
What does F35 code mean and what to do?
  • Run an empty cycle without using any detergent. Often the fault code displays when too much detergent is used and the detergent sits in the drainage system. A cycle without any detergent is often enough to clear out the buildup.
  • 2 Pull the drain hose out of the standpipe mounted to the wall behind the washing machine. Complete a visual inspection of the hose for any clogs. If you see any, remove the screw that holds the hose clamp onto the discharge pump and then force water through the drain hose with pressurized water from a garden hose. Reattach the hose and then run an empty cycle to see if the code goes away.
  • Read more : http://www.ehow.com/how_11368049_fix-whirlpool-washer-f35-code-alert.html
    Oct 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore Elite He5t front load washer. SUD shows for a few minutes then up comes error code F35. Then all controls are locked out. Unplugging machine and allowing reboot fixes problem for a wash load or...
    Remove the lower front panel and unscrew the cap from the pump and drain the water and clean the filter and then run it a few times with no soap at all an dit should clear the system ,,, have some towels handy when you remove the filter.
    If the problem remains unsolved, then you need to replace the pressure switch.
    Explanation
    Sud" SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
    All possible reasons
    • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
    • Check the drain hose and make sure it is not plugged or kinked.
    • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
    • Check/Clean Drain Pump Filter of foreign objects
    • Check Drain Pump
    • Check Pressure Switch
    • Check CCU
    As i mentioned, on most occasions, this is due to faulty pressure switch.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Aug 01, 2011 | Kenmore Elite 45986 Front Load Washer
    I am getting both the SUDS and F35 errors on my Kenmore Elite HE3t steam washer. How can I check the drain filter to clear any debris or build up?
    Hello & Welcome to FixYa
    F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
    Kevin
    Jun 03, 2011 | Kenmore Elite 45986 Front Load Washer
    Error code f35
    F35 (on some models)
    ANALOG PRESSURE SENSOR FAILURE
    If this failure is displayed, there is any malfunction of the steamer
    component detected by the Steamer Electronic Board.
    Possible Causes/Procedure
    Check if pressure hose is fixed correctly.
    Check if the airtrap is not blocked.
    Check if the hose is not blocked.
    Make sure you are ONLY using HE SOAP!
    Correct usage amounts are as follows:
    Regular HE SOAP = 2 Tablespoons
    2X HE SOAP = 1 Tablespoon
    3X HE SOAP = 1 Teaspoon
    The information on the soap usage comes directly from Whirlpool Tech Line.
    SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE
    WASH CYCLE)
    If suds are detected continuously by the pressure switch during the drain
    or spin phases, the washer will fi ll 4 liters of water and during 5 minutes
    the unit will rest without tumbling, the water will be drained and it will try
    to spin or drain again.
    If too much detergent was used:
    Run through a RINSE/SPIN cycle.
    Run a NORMAL cycle without adding any detergent.
    Unplug washer or disconnect power.
    Check wire harness connections to the drain pump, pressure switch,
    and Central Control Unit (CCU).
    Check/clean drain pump filter of foreign objects.
    Plug in washer or reconnect power.
    Check drain pump.
    Check the pressure switch.
    Verify CCU operation by running a Diagnostic Test or any cycle.
    Apr 19, 2011 | Kenmore Elite HE5t Washer
    Suds and then f35 error code shortly afterbstarting any wash cycle.
    SUDS error = SUDS LOCK (OVERDOSE OF DETERGENT
    DETECTED DURING THE WASH CYCLE)
    If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained
    and it will try to spin or drain again.
    - Run the unit through a RINSE/SPIN cycle.
    - Run a NORMAL cycle without adding any detergent.
    1. Check the drain hose and make sure it is not plugged or kinked.
    2. Unplug washer or disconnect power.
    3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
    4. Check/clean drain pump filter of foreign objects.
    5. Plug in washer or reconnect power.
    6. Check drain pump.
    7. Check the pressure switch.
    8. Verify CCU operation by running a Diagnostic Test or any cycle.
    F35 error = ANALOG PRESSURE SENSOR FAILURE
    If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
    1. Check if pressure hose is fi xed correctly.
    2. Check if the airtrap is not blocked.
    3. Check if the hose is not blocked.
    Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    I have a whirlpool WFW9600TW01 front load washer. It is giving F35 and SUD error codes. I have cleaned the drain pump and lines, cleaned the dispenser, flow regulator and hoses, took out and cleaned the...
    Hi dear.I may have solution for the SUD error.You can give it a go.But I do not know any thing about F35 one
    The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If “Sud” is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
    Potential Causes
    • If too much detergent was used, run the unit through a Rinse/ Spin cycle then a
    Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
    • Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
    • Check / Clean Drain Pump Filter of foreign objects
    • Check Drain Pump
    • Check the Pressure Switch
    • Check CCU
    Replace failed component.
    As it says run couple of rine cycles it should get back to normal.I hope that helps you.Thanks.
    Aug 29, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
    Was ''F35'' now its ''F21''
    F21 is drain problem.
    Try tripping circuit breaker to reset the appliance.
    The next step will be undoing the drain pump hose to check for a blockage.
    the pump is accessed removing a panel, usually at the front side of the machine.
    Steps are explained on user manual.
    Keep a container ready to collect water when you undo pump hose.
    Parts and diagrams available here.
    Nov 14, 2009 | Kenmore Washing Machines
    My washing mashin shows F35; First shows sud
    Check the drain line for kinks or obstructions first. Then check the pump. Remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Check for anything clogging the pump and inspect the pump impeller for broken/missing blades and ensure that the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully, it is just a clogged drain line or pump. Hope this helped and best wishes.
    Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    43 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
