Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
My Electrlux dishwasher keeps dying.
I bought a electrolux diswasher about a year ago. When it was delivered it was DOA. I was sent a new one and 3 months later I couldn't get any electronic display on the door panel, the unit was totally dead. The repairman replaced the door. It's been another 7 months and the same problem has reared it's ugly head.Is this a common problem with these dishwashers or is the problem something other than the door? I don't know the model number because I am at work. I know I paid over $1000 for it.
  • 457 Answers
Alot of times you may look at the dishwasher for the problem but i would have started with the power source from the home. always make sure you are getting 120v from your lines.there is a plug in tool that you can check to see if there is a problem with your electrical. a good electrical supply company has them. tell them you want to check the polarity,at the outlet. Start there first then let me know.
Posted on Mar 09, 2010
Worst product we have ever owned call the manufacturer and demand a refund. Mine is three years old and still presents us with dirty dishes that have scratches and debris everywhere. the phone number is 877-435-3287...don't settle get your money back...I did!
Posted on Mar 10, 2010
Electrolux 24 in. Diswasher
Hello Darlene, thank you for allowing me to assist you!
The "ER" code that keeps appearing on your Electrolux dishwasher stands for a Membrane Switch Failure. Normally that means that your control board has detected a stuck key or key pressed for more than a minute. That could possibly be an issue with your keypad or main control board. I would recommend having a technician come out to your home to properly diagnose and repair your dishwasher. I hope this is helpful. -Matt
Aug 02, 2014 | Electrolux EIDW5905JS Dishwasher
My Electrolux Diswasher Model EIDW5705PS is stuck in Loc mode
Good Morning Friend,
I understand your Electrolux dishwasher, model# EIDW5705PS, keeps getting stuck in LOC mode. I also see that you are looking for another way to reset it, other than having to uninstall it. First, I suggest trying to unlock your appliance by pressing and holding down the "Air Dry" button for 3-5 seconds. If that doesn't work, I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Electrolux EIDW5705PS 24" Stainless Steel...
Error code 01 keeps coming up and will not let dishwasher complete its cycle. My dishwasher no. is ewdw6505gso and it is only 3 years old. I have 2 other appliances that are Electrolux. Please help.
Mine was only a few months old when error 01 arrived - it is a leak. The Electrolux dishwashers have a leak detector at the bottom inside the plastic pan, that when water appears it sets off the code and you cannot restart the dishwasher until you dry the pan out (tip the unit forward and water will come out) but it will keep on doing it unless you repair it - mine was covered under warranty and they replaced a lot of parts at the bottom. Not even a year later it leaked again, but not as bad. I took it apart and removed a fabric pad that sits in the bottom of the pan, it does not go off that much any more since the water evaporates before it does any damage. I think this feature is completely useless - I would rather see a wet spot on the floor than not be able to do dishes... If you got 3 years you are doing well. I will just replace my appliances as they die and never buy Electrolux ever again! PS if a refrigerator is one of your other units, be aware that their main boards can fail and are very expensive to replace. You will know it is blown when your food freezes in the lower compartment and your lights come on instantly instead of glowing up slowly.
Nov 15, 2013 | Electrolux Dishwashers
Once dishwasher starts wash cyle, it keeps running wash cyle indefinitely. what do i need to do
Possible that the diswasher control panel is not in order and is a suspect. remove power for some to reset the board. Try with different program and if the same action continues check with the panel board before you can think of swapping to confirm the case.
Jun 28, 2012 | Kenmore 24 in. 17482 / 17484 / 17489...
What does the display C 8 stand for as i am not able to start the dishwasher
C8 means that at the rinse phase the boiler did not empty.
The reasons are ..
1) the nozzles are blockled
2)Drain pump out of order
3) bad luck
now you must reset c8 from the parameter in order to start again the diswasher
kostas
Jan 17, 2011 | Electrolux 504199 Dishwasher
Electrolux dishwasher error c8 What does this mean please??
The reasons are ..
3) bad luck
kostas
Nov 08, 2010 | Electrolux 504199 Dishwasher
Freezer door of electrlux freezer keeps coming
Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
Jul 06, 2009 | Freezers
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
104 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
