Question about Polaroid i830 Digital Camera
I used my camera just this morning and it was running low so I put new batteries and IT WILL NOT TURN ON....I am sooooo frustrated.
    Brigadier General:
  • 11,967 Answers
Are you sure the batteries are in correctly?
Posted on Oct 05, 2009
Fujifilm s2940 When I turn the camera on it says
It could be a problem of low power battery, put new Duracell battery. IF not solved, send service center there are serious problem in electronics. Go only authorized fuji service center.
If you could run it after changing battery, run a fectory default.
Oct 18, 2013 | Cameras
For christmas i was given a Bush HD pocket camcorder 9909, i've just put new batteries in but the camera shuts down because of low battery even though they're new batteries. It is rather...
You need to fully charge your battery pack. When you buy new rechargeable batteries it has low or none charge at all.
Thanks for using fixya!
May 31, 2011 | Computers & Internet
JUST PURCHASED NEW CAMERA, PUT NEW BATTERIES IN AND AFTER TAKING JUST A FEW PICS, BATTERY LOW INDICATOR CAME ON AND SAYS IT NEEDS NEW BATTERIES. PUT NEW ONES IN AND AGAIN, BATTERY LOW INDICATOR CAME ON. ...
yes, The Flash mode consumes LOT of power, thats why it needs lot of batteries, use " rechargable batteries", or use camera without FLASH, and use GOOD QUALITY battaries
Jan 22, 2011 | Canon PowerShot SX100 IS Digital Camera
Put new batteries in but still comes up low battery
Most likely the batteries you are using is not for "high drain" devices. Digital cameras take very good batteries to run. Regular batteries, even brand new will sometimes bot have enough juice to run the camera. Try looking for batteries "for high drain devices." Rayovac makes some that run my camera fine.
Dec 20, 2010 | Cameras
Camera always says low battery even when you put in fresh batteries..will not allow me to take any pictures
Hello. Remove the batteries and use the eraser on the end of a common pencil to clean the contacts. Then replace the batteries and turn it on. J.
Jul 10, 2010 | Samsung Digimax A7 Digital Camera
Red flashing light on battery indicator on the loading dock.
My Z760 does the same thing. When that happens I run the battery completely down by taking pictures until it shuts down. Then when I put it on the dock it charges properly. Don't leave your camera on the dock all the time and don't try to always keep the battery fully charged--instead it will develop memory and think it needs to be fully charged to run and will give you a low battery signal earlier than it should. Wait until you actually get a low battery signal before charging and it should help, but mine will still give me the red light sometimes. Then I run the battery out like I said before. I hope this information helps. :-)
Mar 14, 2009 | Kodak EasyShare Z760 Digital Camera
Problem with camera battery
mikeandlenna,
I'm guessing you have had the D80 over a year and past the warranty so you purchased a new battery. If the battery is fully charged and reads partial, check to make sure the contacts are clean (the compartment in the camera might have something on it or hopefully not some corrosion) use a dry q-tip to test and see if anything comes off the contact and on to the q-tip, if that's what it is, then you will be back in business. let me know if that's not it and we can try another route.
randy320sgi
Jan 03, 2009 | Nikon D80 Digital Camera with 18-135mm...
Camera is busy or not connected
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 23, 2008 | Fuji FinePix A500 Digital Camera
Battery low all the time
Try Eneloop batteries from Sanyo. They have the higher voltage needed. AND that voltage doesn't sag under the initial startup load.
Nov 02, 2007 | Cameras
Polaroid i830 Digital Camera Logo
109 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
