Question about Xerox Phaser 7300DN Laser Printer
I have problem image unit yellow, when I print out the color yellow it look like not even color do you think the led essembly is some think wrong
    President:
  • 2,072 Answers
The yellow laser could be dirty, the **** glass for the yellow could have toner or dirt on it.
May be the internal components of the yellow image unit itself.
Posted on Oct 06, 2009
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
Yellow background after the first print or copy bizhub c351, how can I run image Quality adjusment
The copier automatically adjust the color calibration every ON/OFF.Clean the LED line located under everyimaging unit(black,yellow,cyan,magenta).
Feb 01, 2013 | Konica Minolta bizhub C351 All-In-One...
Okidata c9650 printer. technician told me to replace transfer belt in my unit because i was having an issue with the color print quality. It had a light streak running through it and the top of the page...
That message is indicating that you need to replace the black drum which also may have been what was causing your origanal issue. Whenever you have a print quility issue print four seperate documents each document using one of the four colors (black, yellow, magenta, cyan)used by the printer. If the problem only shows up in one color then that is where the problem is coming from.
Jan 21, 2011 | OKI C9650HDN Led Printer
Epson C45 printer only print out yellow color.
Run a maintenance clean on it
r click on the printer icon go to properties, then seek the maintenance tab on the header of the print queue and run both clean and nozzle check. When all of colors print the problem is fixed.
In colder times leaving printer in ON mode keeps ink from hardening and blocking jets
Please rate my help++++Thanks for using FIXYA
Jun 12, 2010 | Epson Stylus C46 InkJet Printer
Phaser 7300 dn prints full yellow color background on every page even if the background copy shows no color.
Most likely the yellow drum unit is causing that problem. The charge roller gets worn and makes whatever color it is in print out all the time. That would require replacing the yellow imaging unit.
Feb 20, 2010 | Xerox Phaser 7300DN Laser Printer
Minolta cf3102 printing yellow where white should be
There could be 2 reason for this, first Imaging Unit or Laser Unit, the easiest way to try changing the Yellow Imaging unit, If the problem is not solved, Swap the laser unit yellow one with another laser unit,check if the problem is shifted to the color to which laser is changed
May 07, 2009 | Konica Minolta Office Equipment & Supplies
Getting Yellow half way up the page
That is a common problem with commercial color printers using the larger color print cartridges. Change it using the same vendor and ask for an exchange credit.
Aug 27, 2008 | Sharp AR-BC320 All-In-One Led Printer
Oki c5100n printing colors offset
posted by Halfwalkeer on Nov 13, 2007 Report abuse
Just replaced the color toner cartridges in the c5100N, two OKI (cyan and yellow) and one non-OKI (magenta). Now it appears that registration is completely off.
When printing an image, there is a band of yellow at the top about 6mm high, and a band of purple (not cyan) at the bottom about 6mm high. It seems that the yellow printing LED array is printing offset. I've verified this with a typical test page that shows yellow blipped up by several mm.
What the hell happened ? How can I fix it ?
Thanks -
Dean.
Comment by Halfwalkeer, posted on Jan 02, 2008 Drums are all at 34%. Please don't tell me that the drums only have a 50% lifetime on them, because that would just suck royally. When you say the problem is most likely drums, in what way ? What could have gone wrong ?
I was able to more or less fix the problem ... It took several iterations of ColorMenu->Adjust Registration followed by Maintenence Menu->Menu Reset, but it was finally able to pull the registration back into line.
I got worried at one point - after it was "fixed" the printer was powered off. Upon powerup again, registration was off by several centimeters ! Another round of the above finally "fixed" it again, but I haven't powered it down again.
It was a cheap printer. Maybe this is why ...
postsolution.gif Post Solution addwq.gif Work Queue sameproblem.gif Have the same problem? X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Solution #1 posted on Jan 02, 2008 0%20stars.png
4d566c2.jpg Soulvisitor
Rank:guru_s.gif Guru
Rating: 86%, 674 votes
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Comment by Soulvisitor, posted on Jan 02, 2008 I was thinking about the band of yellow being caused by cleaning blade wearing on drum, drums are garenteed by oki if over 50 %, under that one is on their own ie purchase new if having problems with them
If you can fix problem doing colour calibration then faulty drum is not likely the issue.
Cant stress how many problems are caused by non gen consumables in machines, highly dont recommend their use.
Nov 13, 2007 | OKI C5100n Laser Printer
Background Color
1) In the Applications Menu on your copy screen there should be a option to turn on or off a background color fill. Turn it off and try. If it still comes out try hitting panel reset. If this doesnt work. 2) You have a bad Image Unit. Change the yellow image unit. 3) You may also have a bad write unit. Pull out the four write units and check the yellow write unit. It may have gone bad in which case it needs to be replaced.
Jun 12, 2007 | Minolta CF1501 Copier
Xerox Phaser 7300DN Laser Printer Logo
228 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
