Question about Dell Computers & Internet
Loud noise grinding sound computer works ok. Noise seems to be coming from fan cpu area
  • 3,153 Answers
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
If it the Powers supply fan then these ase sometimes replaceable.
Beware howeve that even after disconnection high voltage may still be present.in side the PSU.
Better to replace the whole power supply witha the same or greater wattage.
Posted on Oct 05, 2009
I have an older model Avanti Wine Chiller that began making a very loud almost-grinding noise last night. It continues to cool but I have turned it off due to the deafening sound. Any ideas?
first off determine where the noise is coming from what area? I suspect u may have a fan or condenser fan problem restricted , impeded or going out?
Feb 25, 2015 | Avanti Refrigerators
The water dispenser in our GE side by side fridge model gss25wsti made a loud grinding noise and stopped working Has anyone experienced this or have any suggestions
First the water dispenser will not make any grinding noise while dispensing water perhaps a hum. The grinding noise is from the auger motor which dispenses crushed ice ad ice cubes. So please check the intake valve at the rear of the fridge if its working, if not you may have to replace the intake valve. Or if that"s ok please check the control module on the door of the freezer.
Jan 13, 2014 | Refrigerators
What happened to my Samsung RS255BASB is a loud noise coming from the back of the fridge, one third the way up. sounds like a bad fan/ grinding fan. from the inside it's behind the area where there are...
The sound is of the fan touching the liner. They only way out is to change the bearing. And temporarily you can tap the area where the noise is coming from. When the fan straightens out the noise will stop. But this is not the remedy.
May 14, 2011 | Samsung RS265LABP Side by Side...
A loud grinding noise comes from the fan area
Check if there are dust debris on the fan, it could create a grinding noise, but if the fan is clean, there could be a mechanical problem with it. Hope this helps
Dec 11, 2009 | Acer TravelMate 4200 Notebook
The fan in modem makes loud noises at times
Modems don't have fans.
I think you mean your fan in the computer makes a loud noise. Some computers have settings where the fan speeds up if you are doing a lot of things--making the computer work harder.
Some fans make noise just before they fail. Depends on the type of noise. If it's a sound that has a lot of rattling in it or maybe a high screeching sound, I'm thinking you'll be needing a new fan. Probably a CPU fan is the culprit. Also, fans on video cards often go bad--so you'll have to open the case and listen to where the sound comes from.
Oct 25, 2009 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
Loud noise when turning on my computer
THIS IS NORMAL!!!
When the machine boots up the fans are running at full speed, and after a moment the bios loads teh power management that lowers the fans to the needed speeds. If you tax your computer the fans will speed up to compensate for the heat produced and will get louder then as well...
The larger and more powerful your CPU and Video Card the louder the startup will be. Some of the newest quad core computers with high dollar vido cards will sound like a jet taking off when starting up, I know mine does!
Aug 11, 2009 | E-Machines eMachines Desktop PC
Hp laptop dv9500 noisy and loud fan ...
The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
The fan needs to be replaced.
Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
LG Refrigerator/Freezer Model GR-762DEQF
you will need to replace the fan the reason it stops it the door switch needs to be closed for the fan to operate. with the door open press the switch and see if that is in fact where the noise is coming from if so it sounds like the bearings are going out
Feb 16, 2008 | Refrigerators
LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
Computers & Internet Logo
344 people viewed this question
Alun Cox
