Question about Hamilton Beach 67150 HealthSmart® Juice Extractor
Motor burner out. Do I consider replacement motor, or go to a better, larger unit?
    Problem Solver:
  • 5 Answers
That model was recalled...best you get a new one
Posted on Dec 31, 2009
  • 41 Answers
New unit. The motor will cost more than a new unit.
Posted on Oct 06, 2009
Juicer stopped working
It sounds like a warranty issue if you bought it new. I checked the internet and this seems to be a budget juicer. I had the Jack La Lane model and fortunately the base unit (motor) was replaceable, however I concluded it was such because it wasn't heavy duty and they made money off it failing after a year. These are my personal feelings that you should look at a better model and of course you will pay more for the quality.
Mar 20, 2014 | Hamilton Beach 67800 HealthSmart Juice...
The screw on the drive motor is broken. This is the ABS drive screw that connects to the shredder disk. Is it possible to get a replacement part? Thanks
The Jack LaLanne website does make some replacement parts available:
https://www.unitycart.com/pjss/parts/parts_pro.asp
If what you need is not here I would suggest you contact the company and see if they are available to assist:
http://www.powerjuicer.com/power-juicer-customer-care.php
If this a part that they do not make available you might consider contacting some small appliance repair shops in your area to see if they have a used machine they are using for parts.
Mar 10, 2011 | Tristar Jack LaLanne Power Juicer Pro
The blade wont spin even though the mothor is on. I can hear the motor engage but the blade will not move...it has not been used in awhile.
Have you ensured that the blade is securely screwed into the drive motor? Using the two-pronged tool that came with the juicer (or, if you've misplaced it, a DIY solution like two small screwdrivers), make sure that the blade unit is screwed clockwise onto the drive motor. There should be two holes on the inside of the blade unit, at the bottom of the "bowl." That's where you remove the blade unit for cleaning and reattach and tighten it.
Mar 01, 2011 | Jack Lalanne Power Juicer 250 Watts
Hello I dropped my juicer and the motor works but shaft won't spin
Hello !
The stainless steel shaft might have misaligned from the motor bushing due to the fall.
But, It would be risky if you tried to open the motor assembly and realign it by yourself, a service man is usually the experts on this.
You can try first to lubricate the shafting with an oil and try to rotate it and see if it moves freely.
You can also inspect if the seal from the shafting is not broken. better replace it if you found one.
The bearing also is most like to be damaged and will need to be replaced.
This link might be helpful if you want to order parts from internet
http://ecommerce.hacres.com/Champion-Juicer-Body-Hub-Oil-and-Seal-White
Nov 23, 2010 | Champion 2000+ Household Juice Extractor
I purchased a Hamilton Beach juice extractor, Type CJ01, Model 395W from a thrift shop. No manual available. How do I remove the circular blade cup to clean?
The solution i have found is relatively simple, but going to take a bit of handy work.
first, it would greatly help to remove the bottom from the unit. You will need to remove the 4 rubber pads, and then the 4 screws. 2 of the screws are way up there and need a thin philips.
Regardless if you removed the bottom, you will need to drill a hole right in the center of that circular grill on the bottom piece.
If you did NOT remove the bottom piece, I would take a nail, clamp it with vice grips, get it red red hot off the burner, and burn away that center plaster to create a hole. So whether you drilled the hole (with the bottom removed) or burned the hole (with the bottom intact), you will see the bottom of the motor has a slot head.
Now, all you need to do is take a thin blade screwdriver, or thin butter knife into that slot, holds the motor, then twist the blade right off...or on...whichever the case may be.
Hope this helps...sure helped me!
Oct 30, 2010 | Hamilton Beach 67800 HealthSmart Juice...
The juicer overheated and stopped working
The motor sounds like it overloaded, I doubt it has a thermal cutout fitted (in which case you could leave it off for a while and see if it works) I doubt it has this feature and if it is the motor then the unit should be replaced.
Jun 20, 2010 | Breville JE900 Juicer
MP-80 240 Watts Juicer: where do i go to find a larger image of this parti...
Larger image as in an image of all of the parts, or just a photograph?
I have access the the Ownes Manual if required.
May 18, 2010 | Braun MP-80 240 Watts Juicer
I have a maytag model mgd9316aww gas clothes
sound's like silanoild's on gas valve not opening to let gas in.
Nov 15, 2009 | Juicers
My UNIT-does nOt operate at all.
Hey if you have not gotten this resolved already, here are some things to consider.
I have the same unit. It will not operate is any little thing is left undone. So, I would recheck all of the assembly to make sure all the attachments are properly and securely attached.  The last part to check which seems rather minute, but will prevent the unit from working, is to check that the pulp catcher is securely snapped in. There is a small lip at the bottom that must clik in just right for the unit to kick on the switch is pressed.  Once the metal arm is in place, give it a whirl.... and let see what happens.
Hope this helps..
Let me know.
enov8
Feb 08, 2009 | Jack Lalanne Power Juicer (Stainless...
Hamilton Beach 67150 HealthSmart® Juice Extractor Logo
166 people viewed this question
Top Hamilton Beach Juicers Experts
David Payne
David Payne
eyecam
 Russ Hill
Russ Hill
Are you a Hamilton Beach Juicer Expert? Answer questions, earn points and help others
