Question about Garden
Why chemical dispenser is shooting out water - Garden
Ice cubes in ice tray and food smell and taste bad ammonia. I don't have a ice dispenser
Test the water for contaminants. If you're on a well, you need to filter for ammonia and other chemicals in the water.
Feb 17, 2016 | Refrigerators
Water leaking from ice dispenser on jen air model jcd2389geq
Could you please describe the problem you are having a little better?
Nov 24, 2012 | Refrigerators
My refrigerator and freezer smells like chemicals
Your problem might be something caught in the water hoses going into your fridge and condensation is freezing around it
Apr 03, 2012 | Whirlpool Refrigerators
Glasses have a film when dishwasher is done.
There are several things that could cause this; 1. The rinse agent dispenser is out of rinse agent(Jet Dry). 2. The dispenser is not working and is easy to replace by removing the four screws that hold the door panel on and the two that removes the dispenser(be sure the breaker is turned-off). 3. The water temperature coming into the unit from the water-heater is not hot enough. 4.Your water may need to be tested for excessive minerals or chemicals. 5. Low grade detergent may not dissolve correctly.
Jul 28, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
My am-14 is eating the detergent. It use to last a month now less than one week. Is there a soleniod valve thatisn't closing?
The over consumption of detergent could be caused by a couple of things. If the detergent is dispensed by an external chemical pump, the detergent probe may not be working correctly. The probe will cause the pump to dispense too much chemical if it is dirty or has hard water build up on it. You can check the probe and clean it of any debris. The probe is located in the bottom of the wash tank. Most chemical suppliers take care of these sorts of issues at no cost to the customer. If your rinse solenoid is not closing properly, this could cause the detergent to flow down the standpipe (overflow drain). This would make the chemical pump dispense detergent more often then usual. An easy way to check if your rinse soleniod is stuck open is to look at your rinse arms if water is flowing out of them and doesn't stop this would mean your solenoid is in need of repair.
Kind Regards
Feb 26, 2010 | Hobart AM14-253 Free-standing Dishwasher
The water smells in my hot water dispenser
There usually is an anode rod in a water heater that is there to attract the lime from the water. This helps prevent lime build up in the bottom of the tank and makes it last longer. However, the downside of this is the sulfur smell that comes as a result of the anodization (chemical) process. You could remove the rod and plug the hole in the heater to eliminate the smell. You'd give up some length of service as a result.
Sep 07, 2009 | Buck IN-SINK-ERATOR HOT ONLY WATER...
Howto install an auto detergent dispenser onto existing toilet ci
"Fluidmaster" makes a device that clips onto the tank and dispenses a solution into the bowl at each fill after a flush.
It goes inline with the tube runing from the fill valve, and dumps into the flush valve which goes into the bowl when filling.
Most LOWES carries them.
These are better than the ones that release the chemical into the tank because the chemical never has a chance of causing corrosion and failure of the tank to bowl seals.
Nov 18, 2008 | Kohler Santa Rosa K-3323-0 White Compact...
Water Dispenser Shooting Out Water (KitchenAid Superba)
check where water inlet is and water inlet is connected direct to the inlet valve - normally a double valve ie one water inlet and two water outputs. just disconnect wires from valve, making a note of where they go and tape them up
Sep 04, 2008 | KitchenAid Superba Architect KSCS25INSS...
Auto Water Dispenser
that maachine shoulnt work with out the filter inplace, all i can suggest is replacing the filter.
Mar 18, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
