Question about Frigidaire ATF6000ES Front Load Washer
My washer will not drain the water and the spin-Model ATF6000FS1
Frigidaire front loader Model ATF6000FS1 - my washer will not drain the water and the spin cycle will not spin. it does spin on the other cycles. i'm guessing the filter is clogged again. this is the 3rd time it's happened; however, the first time the pump was replaced. i need to know how to get to that area to see if i can unclog the filter. i don't have a parts manual. can someone help me find out how to remove the filter and unclog it?
I had the same problem but bought a new washer. As we were parting this washer out we found that there is a black rubber boot the attaches to the water pump. There is a filter inside of this boot and it was clogged with hair, string, and almost 2 bucks in change. No wonder it wouldnt drain. Check yours and see if thats your problem too!
Posted on Sep 21, 2010
I have a Frigidaire washer 2003 model no. gitr 1670 aso front loader that will not wash or spin. Everything else works like fill with water and water drains.
Hi friend, thanks for your post!
I see that your Frigidaire washer is not washing or spinning but everything else is working properly. I would advise you to check over the drain hose, make sure it is not restricted or too far down the drain pipe. If that checks out it could be a possible problem with your motor or control panel. One of those components could need to be replaced and for proper replacement I would recommend assistance from a technician to have a proper diagnosis completed. I hope this is helpful. -Matt
Oct 08, 2014 | Frigidaire GLTF1670A Front Load Washer
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
I cannot find my pump filter on my front loader washer.
mine is front right hand side underneath the washing machine
Feb 12, 2012 | Frigidaire Washing Machines
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
My front loader, model #FTF30ES1 won't spin out
This could be due to water discharge. Clean filter/ pump if needd be could also be slow motor speed , worn belt/ brushes in motor. good luck
Nov 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Water remains in the washer. Spin cycle does not work. Unit less than one year old. Model ATF6000FS1
The problem is probably the pump being clogged with an object. Typically it is a coin.
Remove the front bottom cover to access the pump. Remove the two hoses. Make sure you have a pan to catch the water from the hoses. You will be able to remove the objects after the hoses are removed.
Jul 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire ATF6000ES Front Load Washer Logo
750 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
