Question about DeLonghi 6707E Oil Filled Radiator Heater
Radiator isn't running when the car is running, it starts when i shut off the car. I dont know if its wiring or something with the radiator?
    President:
  • 3,433 Answers
A very confusing problem. Radiator running? ,do you mean the fan? And the oil filled category conflicts.
Ok, if it is the car the fan will not come on until it exceegs operating temperature. It comes on when you turn off the engine because with a stop of circulation, the coolant in the engine spikes or rises in temp and the fan just keeps it from boiling over and forcing coolant out through the radiator cap vent. Nothing to be concerned about. _Ned_
Posted on Nov 01, 2009
Radiator fans
I dont know what year model you have but the newer one will run when car is turned off to cool radiator. Maybe you have a radiator problem if this just started to happen. Is the car over heating. Did you check radiator fluid or thermostat. I dont know much about your car and year model but i would do these checks. Maybe radiator needs to be flushed. You can use aluminum brite for to flush. Can buy it at O Reiley's. I had to flush my daughters radiator about 10 times when we bought it used, fithy. Looks brand new. Please dispose of chemicals properly. It is an acid.
Apr 16, 2014 | 1993 Chrysler New Yorker
Cooling fans won't turn on
Your cooling fan switch is probably to blame. It is located on your radiator. It switches on the fan when the coolant becomes hot. It is about an inch in diameter and is threaded into the radiator. There is a wiring harness coming off of it. You can jump the wires in the harness and they should start your fan. If the fan turns on from jumping between the contacts on the harness, not the the contacts on the sensor, then you need a new sensor.
Jan 30, 2014 | 1997 Volkswagen Golf
I have a 2002 buick lesabre and the water pump was changes about a month ago. The car ran fine. The last week, the car is temp gauge is reading hot very fast. I dont smell any coolant and it doenst sm
some times when the water pump is changed you gotta fill up the radiator with coolant, run the engine until it gets hot, shut off the car and wait until the car cools down to put more coolant because some air may stay trapped inside and by following this steps you get rid of the air trapped inside.
try this:
1) when the car is cool take the cap of the radiator off and see if it's full. if it isn't, with the car still off, put some coolant until it gets full.
2) once the radiator is full, start your car and wait to see if the coolant goes down the radiator. if it does, keep putting coolant until it doesn't take any more.
Hope to be useful.
Sep 07, 2012 | 2002 Buick LeSabre
I have a 1994 Jeep wrangler 6 cylinder. I replaced the cooland and therostat and it opens like it should at about 100 but the air is still cold. Is there something I overlooked?
Hello! Thermostat should be a 190 degree...you may have an air blockage...Remove radiator cap start engine and leave cap of until all air bubbles are out (even after thermostat opens)...Cap and test for heat...if there isn't any heat...When that thermostat opens and hot water flows through the upper hose of the radiator that hose will be hot and hard..If you feel the heater hose only one will be hot which means that nice hot water is not passing through the heater core...That could be due to blockage or the control in the car isn't opening the valve on the core...check to see if the heat control is opening the valve...If it is, I would suggest that you purchase a back flushing kit ($10) A plastic tee fits into the inlet heater hose and a garden hose is then connected to the tee...Drain the radiator, remove the thermostat, and turn on the water...do this with heat control on high...The system will back flush out of the top of the radiator and hopefully clean the blockage...Reassemble ...Cap off the tee (cap is in kit)...Install thermostat (190) Is a better choice...Refill radiator...Start engine and leave the radiator cap off until all the air bubbles out............At that point you should have heat...Guru...Saailer
Jan 01, 2012 | Cars & Trucks
I would like to know the actual temp it should run after changing thermostate. It runs about 1/2 way up. But when you cut it off and restart it its above 1/2 for a minute or so. I bleed the air valve on it...
When you run the engine, the coolant will remove heat and release it in the radiator. After you shut the engine off, the heat from the cylinders will still be there and the coolant will heat up some more. This is normal since there is no cooant circulating through the radiator.Without an actual temp gauge, there isn't any way of knowing just how much warmer it gets. I own a 1994 F 350 and have installed actual gauges. I can run my truck and watch the coolant temp. If I shut it off for up to 20 minutes, the gauge will go up ( sometimes as much as 20 degrees) when I start the engine, but return to the normal temps as the coolant is ciculated through the radiator.
Aug 06, 2011 | 1997 Nissan Pickup
Just purchase 1986 vet with heating problem. It heats up within 1-2 minutes of starting. I have removed the thermostat. I can feel no heat in both radiator hoses and there is a pinhole lead in the...
Mine does the same thing everybody at jasper racing told me as long as it dont run above 225 all the time dont worry it should run 210 or so as for the elec my had a short beside the battery there is a power wire there that has a bad route to run so i put a longer wire and re routed it no problems since..hope this helps
Oct 22, 2010 | 1986 Chevrolet Corvette
I change thermostat radiator cap I flush the radiator and it still geting hot. I noticed something the fan don't turn on until it reaches the line in the half of the temp. Gauge and only is on for 40 secs....
CHECK COOLING FAN FUSE AND RELAY.IF BOTH ARE GOOD.HOT WIRE COOLANT FAN.IF FAN DONT RUN FAN MOTOR NEEDS REPLACING. IF FAN MOTOR RUN WHEN YOU HOT WIRE IT.YOUR FAN MOTOR ELECTRICAL WIRES DAMAGED OR HAS SHORTS OR THE COOLANT TEMPERATURE SENSOR FAULTY.
Jun 23, 2010 | 2001 Dodge Neon
Overheating
You have an air lock in the cooling system.
Do this: pull upper radiator hose off the radiator leaving it connected to the block, pour coolant into hose until filled ( you might have to do it to the radiator also). Once filled reconnected hose back to the radiator, then fill resevior to proper level. Start car turn heater on full. Let car run with cap off resevior until it starts pulling coolant in. Once warmed up shut car off let cool. Check fluid level again.
Jun 18, 2009 | 1998 Ford Taurus
Replaced topr radiatior hose on 200 9-5 saab now engine overheats, engine light on. Air does not work as well
a couple of things....change out the thermostat,and check to see if you have water dripping from your water pump.if you do then change out your water pump.and check if both top and bottom hoses are getting hot if they are then that means water is circulating through your engine which is a good thing.
Apr 27, 2009 | 1999 Saab 9-5
DeLonghi 6707E Oil Filled Radiator Heater Logo
80 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
