Question about Seagate Barracuda 7200.7 160 GB Hard Drive
Seagate Barracuda and Samsung SV0411N Master-Slave Combination
Hi Sir,
Previously I was using 40GB Samsung SV0411N 40 GB Harddrive for my PC. I purchased 160GB Barracuda ST3160215A. Now my OS WinXP SP2 is installed on ST3160215A and I want to use SV0411N as slave. But after trying all possible combination I could not start my PC connecting both Hard Drives. I want to get all data from SV0411N but I am unable to connect it with ST3160215A. Any Idea how can I do this? Please solve my problem.
  • 76 Answers
SOURCE: hard disk failure... unable to start
You need to get a new Hard disk. There is no way to get info off the Hard disk that won't turn in because theres probley a short a an element that failed and burned out. Hope this helped. =)
Posted on Feb 25, 2008
  • 46 Answers
SOURCE: how to tell which jumper is master and which is slave
normally most harddrives are the same, copy the other one see if that works.
Posted on Mar 28, 2008
  • 11 Answers
SOURCE: SATA HDD make SLAVE
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
Posted on Nov 24, 2008
landsend
  • 1066 Answers
SOURCE: configure hard disck to slave
you have a diagram on the hard drive that shows you where to install a small jumper tab.  Make sure you also remove the master jumper position.  Be careful
Posted on Apr 01, 2009
astro_boy
  • 103 Answers
SOURCE: How do to install slave drive Seagate Barracuda
if y0our going to slave one hardrive you need to set that hardrive jumper into slave format....check your hardisk if where pin should it e placed...usually there is a direction where to set the jumper for slaving the hardrive.
Posted on Oct 28, 2009
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Unable to load os
check the operating system Cd could be bad version, try other one, if still the same , format your harddrive long way not the quick way.
Jul 11, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
I have a problem .i.e my seagate barracuda 160gb HDD is not detecting in bios .it is a new HDD
Its a master/slave problem. Put it to cable select mode
http://www-307.ibm.com/pc/support/site.wss/42470_hdd4.gif
Put the jumper to CS then reboot.
Nov 14, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
How to tell which jumper is master and which is slave
Master is 7-8 (the 2 furthest from the power connector)
Slave is no jumpers selected
Here is a manual for your model for reference:
http://www.seagate.com/support/disc/iguides/ata/cuda7200ig.pdf
Mar 28, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How to install seagate ata IV hardrive
The easiest way to upgrade from your old HD to the new 40Gb HD is to clone the old to the new. Do a google for "hard disk clone" freewares. Personally I use Partition Magic and have had very good results.
Hardware wise, you need to install the 40Gb as a slave to the old HD by connecting the same IDE cable as that of the old HD (you may have to remove your CD/DVD temporarily). You also have to temporarily remove the single jumper of the 40Gb to allocate it as a slave to the primary master (old HD). Plug in likewise the 4 wire power connector. On power up go to your CMOS/BIOS setup to verify that your PC autodetect the 40GB (you may have to do a manual detection). Boot your PC and go through the normal boot sequence. Thereafter download your clone software choice, install and run. Follow on screen instructions. You may need to reboot. After completion, use Windows Explorer to verify that everything has been copied. Power down, remove the old HD, relocate IDE cable connector of the old HD to the 40Gb, reconnect your CD/DVD, and place back the jumper of the 40Gb. On popwer up go again to your CMOS/BIOS to verify that the 40Gb & the CD are detected. Save & exit, reboot.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 18, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Harddrive
Hi, Looks like it will be a motherboard issue not Maxtor (ATA) and Barracuda (SATA) combination. So the question really would be if your motherboard would accept and recognize the Barracuda SATA. Post back with your motherboard details, (brand/model/version). Kind regards.
Aug 30, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
SAMSUNG SV0411N HDD SHOWN ONLY 7.85 GB
you seem to have a hidden partition Have you used FDISK ? this can be downloaded just do a search You then need to remove all partitions - you seem to have only formatted part of the drive.
Jun 02, 2007 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Seagate Barracuda 7200.7 160 GB Hard Drive Logo
121 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
