Question about Haier Televison & Video
I can't get the color, contrast and other color adjustments adj
I can't get the color, contrast and other color functions adjusted to get a good picture The reds are too shiny red. flesh tones are shiny red. picture is dark
I took the tv back and bought another one. got a three year warranty thaanks
Posted on Oct 07, 2009
What are the best picture calibration settings for the sony 4k xbr65x850a tv
Brightness to 40 > 50%, Contrast to 65 > 75% & Color to 30 > 35% must give a good picture. First, try to adjust a good B/W picture, by adjusting the brightness and contrast. After you have got a good picture in B/W, then advance the color intensity, according your viewing taste. Gopakumar Gopalan Google
May 30, 2014 | Televison & Video
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
How to adjust picture color
To adjust color first of all set contrast and color controls to minimum,adjust the brightness to see clear picture than add contrast to get perfect black and white picture than add color to it for a good quality color picture.
Jan 22, 2011 | Symphonic ST419E TV
Ti 85 wont turn on, batts good, tried to adj contrast , still nothing
Are you sure the batteries are in correctly? They alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. You tried adjusting the contrast. Just try adjusting upwards. Sometimes it takes a little for The Ti 85 to come on or adjust right. The Ti85 is an old calculator and, may not work any more. I had my Ti89 for almost 20 years so, they are pretty reliable. If nothing has worked take out all the batteries including the small one in the back. Texas Instruments say's " leave them out for 5 to 10 minutes." I had to leave mine out for over a 1/2 day to get it to work.
Here is the battery reset procedure for the Ti 85.
Try a new set of AAA batteries.
  1. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing
    the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the
    AAA battery and then turn the calculator on.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute
  4. period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Just keep trying. Sometimes they can be a pain.
Dec 28, 2010 | Texas Instruments TI-85 Calculator
Imagerunner 2270 - When we make copies it is shifting the print down about a 1/4 inch. I think it is a calibration issue but not sure how to correct it.
Try making a copy directly on the glass with the top down. If this isn't correct then you have to go into service mode. Be careful of what things you highlight in this area because there could be problems after. Press the additional function key and then press the " 2 & 8 " keys at the same time, then the additional function key. If it doesn't work the first time press the reset key a couple of the times and start over. You should see something like copier, feeder, or fax depending on what configuration you have. Press COPIER, ADJUST ( across the top ), then ADJ-XY, ADJ-X ( this adjusts the image top to bottom ). ADJ-Y-DF adjusts the reading start position from the Document Feeder. Good luck.
Nov 30, 2010 | Canon imageRUNNER 2270 Copier
Colors are off on the TV. When I try to adjust the contrast and brightness, etc from the menu, either everything is orange or green or yellow.
Contrast and brightness won't fix it.You are on the right path though.You need to search around for a color adjustment.You should have numbered scales for all 3 primary colors to adjust.It should also be somewhere under the picture option.Let me know if you need better instructions.Good luck!
Aug 05, 2010 | Toshiba 42AV500U 42 in. LCD HDTV
Image registration adjustment on canon imageRUNNER C2620
Did you check the registration clutch? try to clean it. Be sure that the paper drawer sensor is "saying" the correct paper size.
May 25, 2010 | Canon imageRUNNER C2620 Color Copier
I wanna send a fax
Sending Faxes.
* Flow of Sending Faxes.
The operation flow of sending faxes is as follows.
Step 1:
Load the original to send on the Platen Glass or the ADF.
Step 2 :
Adjust the fax quality and scan contrast.
Step 3 :
Dial the receipent' s number.
Step 4 :
Send Faxes
- Using the Platen Glass
1) Press the Color or Black button.
If you have two or more pages of the original, load the next page on the Platen Glass and press the Color or Black button
2) After scanning all the pages of the original, press the OK button to send the fax.
- Using ADF
The fax is sent automatically.
* Before sending Faxes
- Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
** Adjusting the Scan Contrast
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among the 3 contrast levels.
1) Press the FAX button, then press the FAX Quality button.
2) Press right or left arrow ot select the contrast.
Pressing the left arrow button decreases the contrast, and pressing the right arrow button increases the contrast.
3) Press the OK button.
** Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
1) PRess the FAX button, then press the FAX Quality button two times.
2) Press the right and left arrow keys to select the resolution.
FAX RESOLUTION - STANDARD
Standard : Suitable for text-only documents.
FINE : Suitable for fine-print documents.
PHOTO : Suitable for photographs.
*Sending Faxes - There are 4 methods for sending functions
a) Memory sending
b) Manual sending
c) Dialing the coded speed dial
d) Redial
a) Memory sending
1) Prepare for faxing
a) Turn on the machine,
b) Load the original on the Platen Glass or the ADF.
Note : You cannot scan double-sided documents from the ADF.
c) Press the FAX bitton.
d) Adjust fax settings as necessary.
2) Start faxing.
a) Dial the receipient's number using the Numeric buttons or coded speed dialing.
b) Press the Color button for color sending, or the Black button for black and white sending. I
c) When the following message is displayed, lad the next page on the PLaten Glass.
Scan Next -> Start
Transmit-> OK
If only one document go to step f).
d) Press the same button as you pressed in step b).
e) Repeat step c) and d) to scan in all pages of the document.
f) Press the OK button.
Manual Sending
1) Connect a telephone to the machine.
2) Prepare for faxing.
a) Turn on the machine.
b) Load the original in the ADF,
c) Press the FAX button.
d) Adjust the fax settings as necessary.
3) Lift the handset of the telephone connected to the machine.
4) Dial the receipient's number on the telephone.
5) Talk through the handset to the recipient.
If you hear a high-pitched signal instead of the recipient's voice, go to step g),
6) Ask the recipient to set recipient's fax machine to receive faxes.
7) When you hear a high-pitched signal, press the Color button for sending color sending, or the Black button for black & white sending. Then hang up the handset.
Dialling The Coded Speed Dial
1) Prepare for faxing.
2) Press the Coded Dial button.
3) Press the Numeric buttons to enter the two-digit code (00-19) assigned to the number you want to dial.
4) Press the Color button for color sending, or the Black button for black & white sending.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Nov 27, 2009 | Canon PIXMA MX310 All-In-One Printer
What is the Digital Effects Control (DEC)?
With this function, you can adjust exposure, contrast, and saturation through the viewfinder itself, prior to image capture. You can check how your adjustments will look using either the viewfinder or the LCD monitor. This feature makes it easy to get the unique images you want in many different shooting situations. DiMAGE 7i is capable of setting contrast, color saturation and filter in the following increments. Contrast: In seven levels from -3 to +3 Color Saturation: In seven levels from -3 to +3 Filter: In seven levels ranging from warm (reddish) to cool (bluish) colors.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Image adjustment functions
SHARPNESS - The function is to adjust sharpness of capturing images. CONTRAST - The function is to adjust contrast (distinction between light and dark) of capturing images. SATURATION - The function is to set color depth of capturing images. GRADATION - In this function, you can select the brightness of an entire image. It is suitable when you want to add a brighter effect to a bright object (Hi Key) and a darker effect to a dark object (Low Key).
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Televison & Video Logo
268 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
