Question about GE WSXH208A Front Load Washer
Where do I obtain a speed control board for the GE model WSXH208A THAT HAS A PN22187000.0
    President:
  • 1,304 Answers
Call 1-877-477-7278
appliance parts pro
part number
AP2620108
runs like 230 dollars hope your right
Posted on Oct 08, 2009
Water won't drain on the wash or rinse cycle
Hi.
If the machine does not drain the parts to be tested are rain system, motor and control board must also be tested. If machine is a top loader testing will start from lid switch. The first action will consist in checking the drain hose at the back and checking the drain filter accessible from lower front side of your GE WSXH208A.
Here a page about drain and spin problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 14, 2011 | GE WSXH208A Front Load Washer
GE WSXH208 Washer - Filter is CLEAN - Could it be the Control Circuit Board? Live in a condo where many residents have this washer and experienced the same problem. Final spin never kicks in fully...
Hi this either a speed control board which is located in the bottom of the washer, or a bad latch assembly on the front where the door latches into, the board is the more expensive of the 2 but usually the board is the problem. there is not a very easy test for either one, one quick test for the latch is if you start the washer and it locks the door and you let it run 2 mins or so and then turn the washer back off how quickly can you open the door? 10 sec? or like 30-40sec? If its like 5-10secs you have a bad latch. Otherwise i would lean towards a bad board. The board is about 125-150.00.
Sean
Mar 27, 2011 | GE WSXH208A Front Load Washer
I have a front load washer an it want spin
hello it's got to drain before it spins so check the pump first if the pump ok and it still wont spin the fault could be the module board this control the motor speed hope it helps
regards
shaun
Mar 10, 2011 | GE WSXH208A Front Load Washer
I think I need to reset my front loader (adora GE) How do I do that?
Unplug unit, Plug back in.Rotate control knob to correct Model number.Press and hold start key till beep is heard,press power key to reset
Oct 22, 2009 | GE WSXH208A Front Load Washer
Spin cycle will not spin
it is possibly the pcb control board that has gone, the motor spin relay should be incorporated in it which sounds to have gone faulty.
Apr 05, 2009 | GE WSXH208A Front Load Washer
Ge front load washer model WSXH208A Will not spin
Mine kept stopping mid cycle also, pouring water on the floor, then the start/pause button flashed and the door unlocked. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Oct 13, 2008 | GE WSXH208A Front Load Washer
Ge front load washer, 7 years old
speed control module faulty replace it .Close Ireland bye bye
Nov 22, 2007 | GE WSXH208A Front Load Washer
Won't spin
is the speed control built in to timer control, check presure switch by blowing trough it,it should click twice if its ok see how you get on ..close ire G>Luck
Nov 01, 2007 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
112 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
