Hi John,
I have the same amplifier, a Sky + HD box, an LCD TV an surround speakers. We wont go into the Wii, PS3 and PC also hooked up. Essentially the best way to go (whatever you connect up) is to split the video and audio signals.
Sky: The Sky box has an audio outputs (left and right channel) found at the back of the box. You get some twin audio cables, plug into the back of the Sky box and the other end into the Kenwood Amp (for example we use Video 1). This means that the sound from Sky can be found on Video 1 on the Amp.
You take the video signal (picture) from Sky using a SCART cable and put into the back of your panasonic TV. This does mean that you can watch a picture without the sound and listen without a picture. The Amp remote controls the sound, the Sky / TV remote controls the picture.
You may need to tinker with some settings on the Amp, for example on the front of the Amp you will find a source button, toggle through the 3 or 4 options to give you the right sound. But essentially that should be it. The same process is used for any other things you want to add, like a DVD player, a games console and so on.
Hope this helps.
Regards, Mohammed
