Question about Sirius Starmate ST2 Satellite Radio Receiver
Sirius starmate 1st generation
Have had the radio for two years, now it is getting power,but showing "acquiring signal" display? any ideas
  • 1 more comment
  • whatcanido Dec 27, 2007
    I am having the same problem, the "Acquiring Signal" message. I have checked my antenae and it is fine. My unit is 18 months old.
  • Anonymous Apr 23, 2008
    Mine worked perfectly until last night. I'm now only getting a varied terrestrial signal along with a message "aquiring satellite signal" What's that all about?
  • Toofoe May 15, 2008
    Having trouble keeping the signal. I have had the antenae in the same spot for two years and one day it just did not keep the signal anymore. Do the antenaes really go bad? Thanks
Try a new antenna...they go bad...
Posted on May 08, 2008
Radio shows antenna not deteted or acquiring signal but does not work . antenna and all connections are good, ??
The problem is likely the actual connection inside the Starmate. It sounds like you have tried alternate antennas, which can only mean the unit itself has an issue. What has likely happened is the antenna jack inside the radio has come loose and is no longer making a connection, in which case it could be repairable. Otherwise there are plenty of other 12v Sirius receivers compatible with the same connections if you are looking to replace the head unit.
Jun 08, 2011 | Sirius Satellite Radio Sirius Starmate ST1...
I have a Sirius Starmate ST2 that is stuck in the Acquiring Signal mode. It is not an antenna problem. The radio has failed. Does anyone know of the fix for this? I know it can be fixed since I've...
More than likely the antenna connection has jogged loose somehow, and just needs to be soldered. The person who handles all of our repairs at TSS Radio does this often, and I'm sure could tell you specifics. His email is sales@tss-radio.com
May 28, 2011 | Sirius Starmate ST2 Satellite Radio...
My Starmate 5 constantly has to acquire signal in my car at home it works perfectly.Any suggestions?
Check the antenna's connector for your car based antenna. Sometimes the little finger tabs need to be gently pushed back towards the center to make a better connection. Be careful not to move them more than a precision screwdrive blade's width or you might snap it off.
Jul 08, 2010 | Directed SIRIUS Starmate 4 Satellite Radio...
If it is reading "ACQUIRING SIGNAL" WHAT CAN THIS MEAN??
This typicall represents a failed antenna with either a loose connection or failed wire to the antenna. The "Acquiring Signal" indicates the receiver is trying to locate and decipher a signal from a sattelite. THe antenna is your first diagnostic. After that the receiver is the culprit. When your receiver is Activated or Authorized it is given a "key" to decipher the sattelite signals If it loses the "key" you can try and have Sirius reinitialize by contacting support. If they cannot send the signal and get the proper "Key" loaded its a defect in the receiver functionality.
Jun 15, 2010 | Directed SIRIUS Starmate 4 Satellite Radio...
Sirius Starmate Power
My Sirius ST1 receiver froze. It reads "Sirius Radio" with the logs but goes no further in booting up. Any solutions?
Nov 12, 2008 | Clarion SIR-CL1 SIRIUS Radio Receiver
I have the same problem. It happens even more with a generic universal power cord instead of the Sirius brand one.
Apr 16, 2008 | Sirius Starmate ST2 Satellite Radio...
Sirius sportster sp-tk1, always displays "acquiring signal"
Hi guys!! I am a sirius satellite radio employee and unfortunately, when this happens (usually when the receiver is about 2 years old) the radio is pretty much shot. It is a common problem with the older sportster models, but not so much with the newer one. As the receivers are probably more than a year old, they are now out of warranty and the only resolution is to call us at sirius and say you want to cancel the subscription on the radio. When cancellation is imminent, we will offer to send you a replacement (although it will be a different unit not compatible with you current docking stations) at no cost to you. Sometimes an antenna replacement will actually stop the problem, but it will happen again very shortly afterward, and thus it is only a temp fix to a permanent problem. Hope this helps you out!!
Feb 15, 2008 | Sirius Satellite Radio Receiver
SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Feb 07, 2008 | Sirius Satellite Radio Sirius Sportster...
Starmate 4 acquiring signal
With the antenna plugged in, it may take a minute to aquire the signal. If it takes more than a minute there is a problem with the antenna or the reciever.
Sep 09, 2007 | Rio SIRIUS Starmate Replay Receiver
Sirius Starmate ST2 Satellite Radio Receiver Logo
315 people viewed this question
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
