Computers & Internet Logo
Posted on Oct 05, 2009
My Abit KV7 will not recognise my new SATA Hard drive. I have flashed the bios with the latest update "20". I can't see the option in integrated peripherals as per the instruction manual
4 Related Answers
Anonymous
  • 2351 Answers
  • Posted on Mar 23, 2008
SOURCE: NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Jerry Umali
  • 979 Answers
  • Posted on Oct 14, 2009
SOURCE: what is the maximum size of hdd to used with abit kv7
Good day sir/maam, yes you can use a 1 TB HDD, get the SATA version depending on the bios but im not sure it be compatible with SATA1 on your motherboard, any new hard disk canor cant be read by any old motherboard, you may have problems with SATA versions, there are 3 versions, but the problem is the response of the hard disk. The rule of thumb, fast motherboards, for large hard disk, because it can access large amount of data very fast usually they are SATA3. So slow motherboards with large hard disk is kinda slow, you be bored. I suggest you stick on the recommended hard disk. If you want extra storage, get 3 hard disk and daisy chained them as master/slave.
Testimonial: "thanks much for your speedy response. I might use the external hdd instead."
Valeriu Dinu
  • 84 Answers
  • Posted on Mar 07, 2010
SOURCE: hi i have a kv7 mobo and trying to connect a sata hdd
first try to disconect all hdd
second only put your new hdd if you know are good
third go
Anonymous
  • 203 Answers
  • Posted on Jun 03, 2011
SOURCE: I have a MSI V
this this site http://www.msi.com/product/mb/PM8M-V.html#?div=BIOS and upgrade your BIOS it may help.
BIOS won't recognise SATA hdd.BIOS is Pheonix-Award BIOS v6. 00PG. Do you think I need to update the BIOS?
Hi, according to your mobo manual it supports SATA1/SATA2 hard drives so it's recommended to update BIOS, the latest I found it has release date 2006-06-29, you can find it in the folllowing link: Support For K8MM MSI Global
Doesn't recognize SATA hard drives. BIOS option
Need to install latest bios update go to there website also if you are trying to boot up with usb installed take it out. BIOS ID:15
  1. Fixed the issue where SATA HDD boot up will fail if USB storage device is installed.
  2. Fixed the issue where SATA HDD boot up will fail if "USB keyboard/mouse" setting as "BIOS" section.
  3. Enhance the compatibility of SATA device on WIN98SE/ME.
  4. BIOS compile date: 06/07/2004
1helpful
What is the maximum size of hdd to used with abit kv7
Abit kv7 hangs at memory speed
Go into the bios and use the "set bios to default" option
There is another that is used for more speed orientated setting but at this point fo not use it.
Also check the memory settings them selves and set them for auto where possible
If you mean that it hangs when counting the memory then try the ESC key as it is booting to get past the memory check and then use DEL to get into bios
1helpful
775Dual-880 Pro cannot detect SATA HDD 320gb
if you bought this board brand new, take it back and tell them the sata controllers in the bois are not sufficent and get one that is. If you got it second hand then you will need to update or flash the bios to the latest version. see if that works and the drive is recognised. if it is recognised via flash/update you may still run into problems if you try to install XP
good luck and regards
2answers
New Hard drive xp install
If your hard drive is SATA and your windows disk does not have SATA drivers on it it will not find the hard drive this is your problem
http://driverpacks.net/DriverPacks/
Go to the above site and download "driverpack mass storage" and slipstream into your windows CD.
I have done this with one windows install disk that could not find disk then it worked perfectly
KV7 upgrade
you might be in luck, the last bios update covers 266 / 333 and 400 fsb cpu's
have a look here
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=2&model=230
Motherboard does not recognise new SATA hard drive
Is your board an ABIT? If so then here is the link to select your motherboard and download the latest BIOS. Make sure to read the web sites instructions on how to update your BIOS. Let me know if you still have issues.
http://www2.abit.com.tw/page/en/download/download_bios.php?pMAIN_TYPE=Motherboard&pSUB_TYPE=Socket%20754
Loading xp home edition
I can try and suggest you check the cables from you CD-ROM, any sort of damage the CD might have. Or then again, if your Hard Drive is SATA connected, then you'll need to load the SATA controler (F6 on the windows instalation) And, in last case, either upgrade your bios or try a different CD-ROM drive unit. But I would defenatly put my money on the cables.
Top Abit Computers & Internet Experts
ExpressFiX
ExpressFiX
JTR44
Level 1 Expert
Grand Canyon Tech
Grand Canyon Tech
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
