Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
My external had drive doesn't show on my computer...
  • yadayada
    yadayada May 11, 2010
    where are u looking for it?
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 05, 2009
My computer doesn't show the external drive
Try plugging the hard drive to a different usb port, if that doesnt work its possible that you may need to update the usb drivers.
Dec 11, 2011 | Fantom Computers & Internet
External drive does not show
Yo! if your external drive doessnt show, its a sign that the drive is corrupted which can be corrected by scanning with a strong antivirus or the drive's crashed which really doesn't have repair.
Jul 21, 2011 | Computers & Internet
Hello, I formatted my external hard drive Samsung G2 HX-MU050DC and i lost the drivers. I can not find drivers. Can you help me please? Because i can no longer read the files that are on it. Thank you...
According to the microsoft site your external hard drive which is the Samsung G2 HX-MU050DC doesn't need any additional software it is automatically installed when connected..Maybe try to connect it to other USB port I preferred you connect it at the back of your CPU..If this doesn't work try to connect your external hard drive to other computer if it still doesn't work. sad to say but the problem is your external hard drive..
Jul 06, 2011 | Samsung G2 Portable External HX-MU050DC/...
When I turn on my 2 terabyte LaCie DD3US external hard drive, disk appears to rotate but I get a red light along with the blue, and clicking noises, and the drive's icon doesn't show on my iMac...
If the device doesn't show up in Mac System Profiler at all or as an unknown device:
The symptoms indicate there is a problem with the drive, how it is connected, or with the computer used for troubleshooting. The next best step is to change physical variables, and find a simpler problem than a broken product.
  • Change the data cable (USB, FireWire, Ethernet, etc.) A failure in the cable can cause this issue.
  • Change the external power supply or cable. If possible, obtain another power cabling to see if the problem is in that component. On drives that are powered via USB or Firewire, try using the included power sharing cable and connect it to another port.
  • Change the computer you are using. Computer problems can manifest themselves in many ways. Even if the computer appears to be working properly, this is a worthwhile test. Try it on a friend's computer and see if it works fine.
If the tests above don't help, it's possible that the drive was either dropped while running, had a hard drive 'head crash' or the circuitry inside the drive is fried.
Hope this helps!
Jun 20, 2011 | Computers & Internet
My WD 1tb harddrive is no longer showing up on my computer. When I plug it in to the USB my computer states the drivers are installed correctly but it is not showing on "My Computer" or any other...
Connect the external drive to another computer and observe if it's going to work perfectly on that computer.
Which ever the case may be, here is what you need to do on your computer;
Insert the external drive into your computer
Go to device manager.
Go to the name of the external drive.
Right click on the external drive and click 'Uninstall"
Allow the external drive uninstall from your computer.
If possible uninstall every other device under the "Universal serial bus controller (usb).
Once this is done, disconnect/remove the external drive from your computer.
Restart your computer.
Wait a while for the computer to boot computer. Also whatever you have uninstalled from the device manager, might install automatically. Which ever the case maybe, make sure your computer has finished booting or installing any device before you attempt to insert the external drive into the usb.
Now insert the external drive and wait for the computer to install the external drive, then observe if it will open this time around.
By now it should open. But if it doesn't open, please let me know so that I may direct you further on what next to do.
I wish you good luck.
Regards.
Jun 12, 2011 | Western Digital My Book Essential Edition...
My vaio laptop with windows XP will not "see" an
Hi mpetersen809,
When you connect your external hard drive, does Windows chime or show an "installing devices" pop-up in the lower right corner of your screen? If this occurs, but you can't see the drive under "My Computer," your external drive might be trying to use a drive letter that's already in use by another device. To resolve this issue, you can manually set the drive letter for your external drive:
  1. Right-click My Computer and choose "Manage." A "Computer Management" window will appear.
  2. In the right pane, under "Storage," click "Disk Management."
  3. Locate your external drive at the bottom of the right pane. Disk 0 is your laptop's internal hard drive, so your external drive will probably be named "Disk 1" or "Disk 2."
  4. Right-click the area of the drive that says "Healthy (Primary Partition)" and select "Change drive letter and paths."
  5. Click the "Change" button, then select an unused drive letter (like Y or Q) from the drop-down menu and click "OK."
  6. Click "Yes" to confirm that you want to change the drive letter.
  7. Close the Computer Management window, then open My Computer to see whether your external drive is visible.
If this doesn't work, there could be a problem with the external drive. Test the drive by plugging it into another computer. If the drive isn't recognized on the second computer, contact Iomega for warranty support or replace the drive.
May 17, 2011 | Computers & Internet
When I switch on the power on my external maxtor harddrive,it doesn' t show on my windows explorer.The blue light in front is constqntly flashing.What goes wrong? Thx lembi sr
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Oct 31, 2010 | Maxtor OneTouch II external hard drive...
LaCie d2 200GB on my Pc (windows xp) via USB 2.0 doesn't show
the situation here is ahppening to all external sata or Esata drives what happens is the external closure has a usb controller when this dies the drive doesn ot spin up or does not reconise simple solution buy a external drive encloser and transfer the drive to it and that will work. thanks and please rate.
Nov 24, 2009 | LaCie d2 (300769) 200 GB Hard Drive
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
733 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
