Question about Water Heaters
I have a halstead ace high combi boiler but it will not light up the pressure is fine what else can i check
    Champion:
  • 248 Answers
Fan, blockage, board, microswitch,
Posted on Oct 15, 2009
Hi, my halstead ace high boiler has started losing pressure and when i top it up to put the heating on after 10 mins the pressure is high whats wrong with it?
Probably a waterlogged expansion tank. The tank provides a springy air cushion for the water to push against as it expands, and the air pushes back as the water contracts. This scheme minimizes the pressure change that would otherwise be caused by expansion and contraction of the water, giving the water somplace to go when it expands. If the air cushion is gone ... big pressure swings.
Dec 28, 2009 | Water Heaters
Halstead ace high boiler making a whining noise when central heating is turned on also pressure reduces after about 4 hours, need to top up verey day.
Whining = pump bearings
Pressure reduction = pressure relief valve diaphragm either perished of gunged up - look for water coming out of the overflow pipe from the valve
leak in ch system look at all joints
Nov 30, 2009 | Water Heaters
I have a Halstead High Ace which will not light up the light flickers then goes off we have fitted a new dectection electrode but still will not light the boiler We also have flushed the system out ....
sounds basic, but make sure the electrode is in the pilot flame
check the overheat thermostat is not jammed on
disconnect and join wires together for temporary override check and run boiler.
Nov 14, 2009 | Water Heaters
I keep having to top up with water every few days, but no leaks to be found, the pressure drops down to less than one and the boiler turns off, please can you help,
what kind of heater combi? if combi you may be pressurising boiler to high ie over 1 bar boiler may be blowing off through release valve check discharge pipe
Oct 28, 2009 | Water Heaters
Heating circuit getting hot when hot water is running
Check to see if diverter valve is in domestic mode or heating mode.
Jul 04, 2009 | Water Heaters
Halstead Finest Gold Combi Boiler water input temp
I know of no limitations on the temperature of the inlet water for any boiler. The warmer the water, the less energy it will take to heat it to desired temp and the colder the water, the more energy it will take. Extreme temps over an extended amout of time in either direction can stress a unit and could possibly, only possibly reduce service time.
Mar 31, 2009 | Water Heaters
Combi Boiler - Hot water pressure low
the coil inside got clogged
Dec 22, 2008 | Water Heaters
How to check if pressure switch on halstead boiler 82 combi
Hi I am thinking what your tryig to say is the air pressure switch?
you can check this switch to see if the boiler works by removing one of the sensing tubes from it & by sucking on or blowing as this willactivate the switch you dont have to do it very hard, just gently as you will hear the switch clicking, if the boiler does fire when you click, in order for it to continue to ignite you may have to fold over the tube, when you release it the boiler should stop.if it does work then you will have to change the air pressure switch, but remember this can only be done by a Corgi Engineer
Kindly
Richie
Dec 17, 2008 | Water Heaters
Water Heaters Logo
1,076 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
