Question about LG LRE30453ST (Electric) Stainless Steel Range
When cooking a roast at 375 in a gas oven does it take longer to cook on the high rack than on the low rack?
  • 546 Answers
YES.
Posted on Oct 05, 2009
How do you cook a hickory smoked ham shank portion that is fully cooked already?
I place ham in a large roasting pan or large rectangular pan using a rack under the ham. Set oven to 325 and cook 15-18 minutes per pound. I make a glaze. I glaze half way through cooking time and then a second time 15 minutes prior to removing from oven.
Apr 16, 2017 | Grilling
What temp and how long yo cook a 5 1/2 pound prime rib roast
Cook the roast for 15 minutes, then reduce the oven temperature to 325 degrees F. Continue to cook the roast until your meat thermometer reads 110 degrees F. Estimate about 15 minutes of cooking time per pound of prime rib.22 Dec 2014
The world's easiest prime rib roast: Master a holiday classic - Today.com
www.today.com/food/world-s-easiest-prime-rib-roast-master-holiday-classic-t77026 What temp and how long yo cook 5 1 2 pound prime rib roast Google Search
Nov 27, 2016 | Grilling
First start up
You're actually referring to the "broiler" elements. Most electric ovens have these at the top of the main oven space. (Some gas ovens are set up the same way, but many put the broiler elements in a bottom drawer.)
As their name implies, broiler elements are active only when you're broiling. They will not go on for baking.
Broiling is the process of cooking food by exposing it directly to a high heat source at close range. To broil a steak, for example, you would place the pan holding the steak on an oven rack raised to the top or next to top position in the oven (consult the manual) and set the oven to broil. The top elements will then turn on and cook the meat by direct radiation.
Most people, however, use ovens for baking far more often than for broiling. Baking is the process of cooking food (cakes, casseroles, roasts etc) by indirect heat. In other words you raise the oven to a certain temperature, put the food on a rack more in the middle of the oven, and let the surrounding heat cook it over time. When you bake the top broiler elements usually don't come on at all.
I hope this helps.
Apr 30, 2014 | KitchenAid Ovens
Whats the difference between a slow cooker and a roaster oven?
a slow cooker just cooks slowly. a roaster oven however roasts food just like in a range oven. they can usually also bake and slow cook also. roasting cooks at a high heat while slow cookers are a lower heat for a longer time. roasters are great to use because the meat tastes really delicious and also the whole kitchen will not get boiling hot like with roasting in the oven.
Jan 24, 2013 | Kitchen Appliances - Others
How long should i cook on high a full crock pot with vegetables and raw meat
when do you want to eat? It usual takes a good six hours on high.
Dec 31, 2012 | Rival Crock Pots & Slow Cookers
How to use the Tesco mtg06 microwave grill?do not have instruction manual
The oven may be used purely for microwaving or simply as a grill for cooking such things as toast. The radiant or quartz grill may be used in a variety of ways. You can use microwaves that have grill functions to roast foods, for baking purposes or for grilling food such as bacon or sausages on the racks. Some models also allow you to use both the oven and grill together, and you can produce fantastically presented meals by using the grill to brown off your dish after cooking. The grill will often have low, medium and high settings for you to choose from, letting you control how brown your food is. By using a microwave with a grill, you can prepare great meals or snacks in a fraction of the time that it would take if you used a conventional oven and grill. Microwaves are particularly convenient, as you don't have to keep checking on the food or stand over it as it cooks.
Jul 29, 2011 | Sanyo Microwave Ovens
Need oven rack position for cooking meat position A,B,C,D,E,F, ?
Depends on what kind of meat you are cooking and if your roasting or broiling the meat?
Jul 19, 2009 | LG LRE30453ST (Electric) Stainless Steel...
Amana Gas Stove M/N ARG 7302WW set temp. is higher than desired t
the oven safty valve is goin bad. that the part that most oven burners sits on.
Dec 09, 2008 | Amana ARGS7650SS Gas Kitchen Range
When I cook or bake in my electric oven things are never done in the recommended cooking time. The heating element is working fine.
hi. thanks for the question. does the door seal properly. check that..sometimes the calibration will go off. what i tell my customers to do is.buy a small oven thermometer, that you hang from the racks . then try the oven at 350 degrees .then look at the oven thermometer . and see what the difference is. so lf ,the oven temp is a bit low .cook at 375. degrees. that will make up the difference . no parts needed. cheap fix. thanks the appliance doc
Sep 28, 2008 | Kitchen Ranges
LG LRE30453ST (Electric) Stainless Steel Range Logo
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
