Question about Texas Instruments TI-89 Calculator
I cant get the stdDev to work, how do you enter teh key strokes
  • Texas Instru... Master
  • 7,993 Answers
Here are some screen captures to illustrate how you set up your statistics. Press [Diamond][HOME][ENTER] . Type in command NewProb and press [ENTER]. It clears old data that may be in lists.
Press [Apps] key then 6 to select Data/Matrix editor. Select New, to create a new data set or current to select the last data set you worked on, or Open if some old data sets exist. Now we select New
Arrow right to unold the data menu and select Data. Leave folder as main or give a different folder name. Name the data set. Here teststd
After [ENTER] data entry sceen I cant get the stdDev to work, how do you enter - 144bdfd.jpgd. Enter values
Identify the columns you want to do statistics on. Here we have only one column, namely c1
Press [ENTEI cant get the stdDev to work, how do you enter - f43ff08.jpg First batc of statistical results are displayed.
Use [Arrow Down] to uncover the rest of the results.
These are the basic steps you follow for most statistical calculations.
Hope it gets you started.
Posted on Oct 06, 2009
  • k24674 Oct 06, 2009
    The screen capture were done on a TI92PLus. Except for keyboard and hardware versions, calculators are similar.
I cant find my wep key i typed my ip address in my browser it just won't work
You need to log onto your router and determine teh WEP key being used. Your router manual has logon details. Also, the WEP key is sometimes on the bottom of the router.
Aug 05, 2010 | ASUS Eee PC 900 Notebook
I have the T7316E system and one of teh extensions does not ring which feature code turns teh ringing back on?
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344. When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)
The display should say line 002: appear only
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Jun 13, 2010 | NorStar T7316E Corded Phone
2006 pontiac montana i cant stop wiper blades mid stroke to change them cant reach them when they return to down in hood again
when running the wipers turn the key off upon were you want the wiper to be positioned at for your work
Jan 01, 2010 | 2006 Pontiac Montana SV6
Can't print or copy with my toshiba e studio 161
H2 indicates thermistor open.
U can enter simulation mode and input "14" to clear the message.
If happen again, u need to check following:
Thermistor
Control PWB
Fusing section connector disconnection
The fusing unit is not installed.
Perform the following procedure to enter the simulation mode.
"C" key AUTO/TEXT/PHOTO key
Main code Start key Sub code Start key
(Note:Perform the first four key strokes quickly allowing no more than one
second between key strokes.)
Jan 15, 2009 | Toshiba e-Studio 161 Copier Copier
Cant reset wlan key password
try a master reset of teh phone then try again
Nov 02, 2008 | Nokia N95 Cellular Phone
I have a toshiba estudion 161, there is error H4 00... what is this can you help me.
1. Entering the simulation mode
If the machine dies enter 14 then press start. the machine will reboot normally.
If not contact service centre
May 06, 2008 | Toshiba e-Studio 161 Copier Copier
When I switch on the copier display H and than 4.. please solve my problem with thanks.
If the machine dies enter code 14 then press start, the machine will reboot normal, if the problem persist, the fuser unit needs replacement
May 05, 2008 | Toshiba e-Studio 161 Copier Copier
Toshiba estudio 161 copier
if the machine dies enter the code 14, then press start, the machine wil reboot and the problem wil be solved, if not , contact your nearest service centre
Cant get thelaptop to work and very fustrating
u need to first configure teh wire less on the router>go to the main computer>and open browse window and and in teh address bar type- 192.168.0.1 hit enter u can see login screen
user name-- admin lower case or blank
password-- admin lower case or blank or password
and u can see the set up scren and select wire less setup in the left side and follow this
Wireless Settings Wireless Network Name (SSID): Region: --- Select Region --- Africa Asia Australia Canada Europe France Israel Japan Mexico South America United States Channel: 11 Wireless Access Point Enable Wireless Access Point Allow Broadcast of Name (SSID) Wireless Card Access List Security Encryption (WEP) Authentication Type: Automatic Open System Shared Key Encryption Strength: Disable 64bit 128bit Security Encryption (WEP) Key Passphrase: Key 1: Key 2: Key 3: Key 4:
Nov 18, 2007 | NetGear WGR614 Wireless Router
Standard diviation
To use one-variable statistics the simple way, go into the Data Editor and enter your data into a column. Press F5 to calculate. Select 1-var stats. I believe you've got this much of it. Then, in the first box, enter the name from the header of the column you entered the data into. For "Use Freq and Categories?" select NO.
When you press ENTER, you should see a screen with the one-variable statistics.
To get the standard deviation the easier way, simply put the data into a llist and then use the stdDev function (or the stdDevPop function for the population standard deviation) function on it. For example:
stdDev({1,2,3}) gives 1.
Oct 09, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
165 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
