Question about Garden
I just got this mower and the blade wont turn, it would't stop at first. after i mowed for aboout 15 min it stopped.
  • fredtoby Oct 06, 2009
    I have an ariens rm828, the blade would keep turning after disengaging, now it won't turn. When it did turn it wasn't fully engaged just engaged enough to turn blade when setting on pavement. Blade stopped when mowing Would also like website to get parts list
    the mower works not the blade, can i find a parts list
    President:
  • 1,723 Answers
Tip the mower up on the side so you can inspect the belt underneath. See if you can turn it by hand? See if anything is obstructing the belt pulley system?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Oct 06, 2009
    Genius:
  • 1,689 Answers
Hi fred,
you may be encountering multiple issues. one is the clutch that moves or controls your transmission and the rolling of the blade. else the gear selector is broken or worn out thats is why you dont have control of the movement of the mower anymore.
best bid is to locate the parts for replacement through isolation. check the belts and your control.
for more information on repair, please click on the links below.
http://www.lawnsite.com/archive/index.php/t-198206.html
http://www.justanswer.com/questions/2i2s5-hi-just-purchased-ariens-rm828
http://www.ssbtractor.com/wwwboard/messages8/6782.html
    Brigadier General:
  • 3,513 Answers
Hi
Check the blade drive belt. Blade drive belts are specially designed to withstand the forces of cutting. The majority of wear on the belt occurs when the blade is engaged. Heavy grass cutting adds stress to the belt. Belt life can be extended by first engaging the blade with the engine at half throttle, then increasing to full throttle for mowing. Always mow using full throttle. When mowing tall grass, cut it twice; using a shorter cut the first time and then lower the blade to the final cutting height for the second round. For mulching, cut only 1/3 of the height of the grass. Avoid cutting wet grass. Wet grass clumps and sticks to the mower deck. The best time for mowing is late afternoon when the grass is dry and not wet.
have you checked the cables, on some self propelled mowers there's a lever w/ cable on the handle that needs to be usually pulled back to engage the drive mechanism.
or are you sure its the right size? too tight or too slack wont let it operate properly.
the pivot point get rusted and dirty to the point that they wouldn't tension the belt enough. Locate the bolt where it pivots and loosen it just a little, then see if the belt gets tight. It must be really tight when engaged almost like a fan belt on your car in order for it to work. I would also recommend that you take a close look at your belt. It could be burned and have a flat spot since it has apparently been slipping. A flat spot on the belt will cause major vibration when the blades are turning.
Thanks for contacting Fixya.com
Posted on Oct 05, 2009
I have a Toro 42 zero turn mower and the blades stop turning while mowing. The PTO switch knob melted. I replaced the PTO switch and the blades turned for 5 min. and then the PTO switch melted again.
Elertric blade drive clutches are a real pain when they go wrong
It sounds like a electrical short is causing the wires inside the switch to heat up beyond the safe melting point thereafter five mins the circuit gets between the fault gets broken as the switch fails the blades stop and the switch melts a bad eaRth corroded may cause this check the deck safety switches are not exposed e.g. they been damaged and the decks metal is shorting them out
a wire has been stripped of protective covering and is touching some metal shorting out something that vital to the blade controls operation the switch is getting a overload and subsequently melting your might need an lawnmower engineer to diagnose to the fault fully and repair
Apr 23, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I was mowing with a timecutter 4200 the blades stopped and won't restart what do i do
check fuses and then start testing the wiring and clutch
Sep 12, 2014 | Garden
Craftsman gt 5000 blades quit turning
is there a wiring rubbing on metal?is a safety switch failing?
Apr 16, 2012 | Craftsman Garden
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
143 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
