Question about Whirlpool Washing Machines
ERROR CODE F28
I HAVE A WHOOLPOOL FRONT LOAD WASHER WFC7500VW, IT IS NOT STARTING AND GIVING AN ERROR CODE F28. DOOR IS ALSO LOCK .I HAVE TRIED TO RESET IT BY TAKING OFF THE POWER SEVERAL TIMES, BUT NO RESULT.STILL DOOR IS LOCK AND NOT STARING
    President:
  • 1,653 Answers
Unplug the machine at the mains. Remove the detergent tray. Reach all the way back with your hand in the slot where the detergent tray normally fits and feel for a lever. When you find it pull it forward. Then replace the detergent tray. Plug the machine back on and the error code will have reset and the machine will be useable again.
Posted on Oct 05, 2009
  • RobH Jul 29, 2013
    That did not fix it. Still getting F DL error code
Whirlpool f28 error code and door lock light
For the F28 error code:
First, check the wiring harness connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
If the wiring connections are fine then It would be a good idea to order both, as both components have been problematic for the error code F28.
Here is a link to the CCU.
Here is a link to the MCU.
Oct 13, 2012 | Whirlpool WFW8300SW
My Whirlpool Duet Front Load Washing Machine is showing a F28 error. What does that mean?
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Jan 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    HE2T front load washer F28 flashes machine is locked clothes inside cannot open help
    tre
    ert
    Sorry to read about your problem, I hope this helps you out.
    The error code F28 means one or both of these parts are bad.
    Motor Control Unit (8540135)
    Microcomputer Machine Control Unit (8540788)
    error code F28
    I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
    4 Thumbs - Very Helpful
    3 Thumbs - Helpful
    2 Thumbs - Somewhat Helpful
    Jan 03, 2011 | Kenmore HE2 Plus Front Load Washer
    Whirlpool wfw8500sr01 door locks and does not start F24 f26 f28 error codes
    DOOR SWITCH ERROR
    If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
    Possible Causes/Procedure
    -Door not opened during 3 consecutive cycles.
    1. Open and close the door.
    2. Verify CCU operation by running a Diagnostic Test or any cycle.
    -Door switch open while door is locked.
    1. Push the door and check if it is completely closed.
    Thanks for using FixYa&^%
    Dec 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    My washer say f28 it is a kenmore HE2 plus
    "F28" means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.Reach up near the latching assembly & attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
    Thank you!!
    Jul 18, 2010 | Kenmore HE2 Plus Front Load Washer
    F28 code
    Thank you!!
    Jul 05, 2010 | Kenmore HE2 Plus Front Load Washer
    It gives a F28 code. What is that?
    F28 is a motor controller error... Try unplugging the machine for a minute or two, then starting it again. If no good, you can remove the access cover and check the connections to the motor... BE SURE TO UNPLUG FROM WALL FIRST...
    Peace,
    Mar 30, 2010 | Kenmore Elite 45986 Front Load Washer
    F-28 code
    F28 means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.
    Reach up near the latching assembly & Attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Jun 28, 2009 | Kenmore HE2 Plus Front Load Washer
    Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
    f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
    Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    F28 error
    F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28.
    Jul 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    554 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
