Question about Marantz SR-18EX Receiver
Marantz SR-18 NO Sound No Data error for DSS (Directv) only
I have a Marantz SR-18, I can't get any sound when I switch to DSS (Directv), I have sound When I use The Tuner, DVD, VCR and the TV when I use the outside antenna, no sound with the DSS only. The Directv is hooked up right , it worked before and nothing has changed just lost sound.
  • 1,113 Answers
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
Posted on Dec 23, 2007
  • 4 more comments
  • Soulvisitor
    Soulvisitor Dec 23, 2007
    this connection I'd like to see moved to one of the ones next to it
  • Soulvisitor
    Also on your remote make sure when in system setup of the On Screen Display, that Audio source is set to DSS.
  • Soulvisitor
    close up of first pic
  • Soulvisitor
    There are other ways it could be connected but I'd say it has been done this way.
  • Soulvisitor
    Also check you are a paying subscriber to the Directv prodvider, signal strengh can be a factor ensure all coax leads and connectors are secure on digitv box and sat/cable link.
    Here is your user manual and spec sheet download LINK
  • Soulvisitor
    What is the brand make model of your Directv Receiver?
I have a marantz sr7200 receiver and i am unable to get sound when its in DSS mode. The sound works in dvd and tuner modes.
In the setup menu, did you set up the input assignments for DSS to be the correct digital input or analog?
Feb 25, 2011 | Marantz Audio Players & Recorders
No sound from TV
check the fuse output line in the speaker! or maybe you are in protect mode! checkout the speaker, maybe you have defective speaker, thats why your unit in protect mode, thats why no sounds coming out!
Oct 06, 2007 | Marantz SR-6300 Receiver
Do have an idiots guide as to how to wire up the SR-4200 to a TV
I will interperate this as:
"So you want to play sound through your Marantz SR-4200?"
You need to clarify what sort of system setup you have, however i will put down a few ways to wire this up to your TV.
If you have a Set-top-box that gets the TV Channels, that is where the sound comes from. If you have a TV that plugs straight into the wall, you will have to get the sound from the TV. Grab a RCA Stereo cable - (White and Red heads, if you don't know what they look like, Google it).
If you are unclear about this, i have tried to make a diagram down the bottom to explain how this is to work. What you will do is Take the sound from the Set-Top-Box or TV and reroute it into your fantastic Marantz SR-4200.
1. Plug Red Plug into the the Red Slot, and White into the White on the back of your set-top-box or TV Out (if you get it around the wrong way, the speakers will be reversed.)
2. Plug the other end of the cable into the back of your Marantz SR-4200 in the TAPE input or VHS input as they are analog signal inputs. Turn on Marantz SR-4200 and turn it onto Tape or Vhs (depending on where you plugged it in).
[Set-Top-Box or TV out] >-------> into >------> [Marantz SR-4200]
If you still don't get it, then try searching You-Tube for a guide "Plug Tv into Stereo". I myself couldn't turn up anything useful
Mar 09, 2010 | Marantz SR-4200 Receiver
I need the remote control code numbers for the SR-18 so I can turn it on with my Direct TV remote.Do you know what they are?
the best thing to do is a code search per the directv manual and hope the Marantz powers off when you find the code.
If it turns off, you have won half the battle. Save the code and try turning the Mar back on.
The issue is that these universal satellite remotes are very limited on there funtionality with audio systems.
Keep in mind that if you find a code that turns it on & off, you will probably be limited volume only. If you get those three functions, you are very happy and call it done.
Hope this helps.
This goes for all sounds systems and not only Marantz.
Jan 19, 2010 | Marantz SR-18EX Receiver
Input signals Marantz SR4003
There are four digital connectors on the back of the unit: 2 optical and 2 coaxial. They are marked a s 1 2 3 4. 1 and 2 are optical, 3 and 4 - coaxial. Also you have front optical connector marked as F.
You can connect 5 digital sources to your receiver. For example, connect your DVD to input 2 (optical) by optical cable and connect your DSS to input 3 by coaxial cable. Assign DVD to digital 2 and DSS to digital 3 in input setup menu.
Aug 14, 2009 | Marantz SR5001
On the Marantz SR-18 amp how do I switch the DSS setting from Dig 2 to Dig 3? Our sound is coming in on Dig 3 and somehow the setting got changed, probaly an errant command on the remote
You have to assign the digital inputs on the setup menu from the remote control while you have the On screen display on a monitor or TV screen.
Feb 10, 2009 | Marantz SR-18EX Receiver
Remote for DirecTV wont control my Toshiba VCR/DVD combo unit
Its true sorry but there isnt any codes available for combos.
Feb 19, 2008 | Directv D10 DTV Receiver
Dtv for 2009
The key is that you are on Directv. So the answer is no. You can't even use the converter boxes with Directv. They are only for watching programs using regular TV antennas.
FYI, based on the online manual, this model TV does NOT have an ATSC tuner built in, even though it has digital audio out. It's only NTSC.
Feb 18, 2008 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
[MSI 8606 TV Tuner Card] Can't get a picture
here is a link for the driver, http://drivers.softpedia.com/get/TV-Tuner-Co/Others/MSI-TV-Tuner-Master-8606-WDM-279165.shtml
Mar 10, 2007 | MSI 8606-020
Marantz SR-18EX Receiver Logo
643 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
