Question about Garden
Making unusuall noise when on stand by. When runing for a while it now stopps working
Hi wont start. just making a loud whiring noise.
According to your description of the fault, something was blocking drain turbine of main motor. Dishwashers always first start drain water because calibration of water level inside dishwasher (empty). In your case, the main motor is same motor for washing and draining. Runing in one direction means washing, runing to oposite side means draining.
The solution is to open a turbine pump and remove all obstacles and visual check turbine impeller,ceramic seal and plastic sleeve on the motor shaft.
Dado
Mar 26, 2015 | Electrolux Dishwashers
Making noise when spinning
bearing going bad, ride it until you cant stand the noise then get another machine, not worth changing the bearing
Jan 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
I went over a pot hole then I heard a loud pop. Stopped and looked under my jeep and there was grease or something all over the inside of my wheel. What was it? Is this a serious problem? Service 4 wheel...
You might want to get all that checked out soon. The grease might be left over from a lube job. But the POP noise, you may have broke a hub or something. If it doesn't make a noise or doesn't wobble, it is not that serious. Make sure the front end is not making any weird or unusuall noises.
Feb 06, 2011 | 2005 Jeep Grand Cherokee
My 04 saturn ion is making a rattilig noise when engine is runing, it 's louder when put in drive, soungs like something is lose like my exause.
It could be only way is to look under the car, but common noises for this car is timing chain guides wear out and chain makes rattling noises. also consider serpentine belt tensioner.
Dec 02, 2010 | 2004 Saturn ION
The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
Apr 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
Jan 08, 2010 | Frigidaire GLD2445RFC Stainless Steel...
2004 Toyota Tundra Radio problem - Popping noise
i had the same thing on my car but it only did it when it was cold it had somthing to do with the tweeters i unhooked them and it stoped making the noise
Jul 09, 2009 | Car Audio & Video
Engine runs vehicle wont move Possible ring gear? 84 Topaz
Is it a metal shaft? When you put it in drive does it make any noise? Does the speedometer move? Does it make a loud clicking sound when you put it back in Park?
May 23, 2009 | 2002 Ford Explorer
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
