Question about Dishwashers
Kenmore Elite dishwasher leaking from the door.
Newly installed Kenmore Elite dishwasher leaks from the left side of the door. We double checked all hose connections and overfill protection float moves up and down freely. Any suggestions on what to check? It is almost like the bottom overfills and seaps out the door seal??
  • 42 Answers
SOURCE: Overfill Protection tripped on ASKO D3112 dishwasher
remove the front toe kick. you should have 6 torx screws. four in the top 2 in the front. your float switch will be in the front center .the float is a piece of styrofoam - the float many times is what you find jammed up making the unit believe it has water in the base
Posted on Dec 21, 2008
  • 9 Answers
SOURCE: KitchenAid KUDP02 built-in dishwasher will not fill with water
Couple of things that come to mind here... May be helpful or not - but after all this is free ifo and probably worth what you are paying!!!
1: Have you tried removing power from the appliance?? All these modern appliances use a microprocessor and - like MS WINDOWS - need a kick up the bum now and then - (Well.. with Windows it seems to be every day- hour -minute - or so)
2: Dishwashers are installed with water reduction valves, so there could be a problem with one of there (particularly the hot water side).
3: The water inlet is controlled by soleniod valves (read: electronic valves). If the valves are not opening, no water will enter the appliance, so there could be a problem with the valves.
Posted on Jan 16, 2009
  • 229 Answers
SOURCE: Leaking?
No it isn't draining properly. You need to clean out the debris mesh at the bottom of the tub under the dryer bar this will usually fix this problem. Good luck.
Posted on Jan 18, 2009
SOURCE: Kenmore Elite Dishwasher - leaks from Overfill Protection Float
I had the same problem, but mine leaked every time. I have a kenmore ultra wash dishwasher no. 665.15762. I took the bottom rotating sprayer off and found that the plastic piece under the sprayer had a few loose screws and the rubber gasket, under that piece, had blown out at the corner facing the overfill protection float. I took out all the screws and re-mounted the gasket in place and put all the screws back and tightened them. It solved the problem. I hope that this helps others.
Posted on Mar 16, 2009
  • 8619 Answers
SOURCE: it doesn't start and clean light flashes
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Posted on Jun 07, 2010
Testimonial: "You solved the problem quickly and easily. Thank you for the great assistance!"
Daniel S
  • 4323 Answers
SOURCE: kudso1ij no water fill after two weeks absence,
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Posted on Jun 26, 2011
0 characters
1 Points
Kenmore elite dishwasher leaking below washer
see this causes and use the common sense. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Sep 19, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
Newly installed. From day one, front door seal leaks slightly. Mostly on the upper left side of door. With door latched, I can still push door in another 1/4". I can not find any adjustment on the...
Most likely the dishwasher is not properly levelled. You will need to adjust the springs at the base to ensure balance on the door is maintained. One side of the door is probably getting pulled more than the other.
Refer page 14 in this manual. if you cannot open the link then got the whilrpool site and select Manuals page and type the model number and go down to the installation manual.
Hope this helps.
Oct 18, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Door seal leaks when operating
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
Aug 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My dishwasher is leaking out the front. It drips from the lower left hand corner. Any suggestions to what is causing the leak?
Either the tub gasket needs replacement (item 3) in this diagram. or the door base gasket needs replacement. Alternatively, the door vent seal could be leaking. Item 4 in this diagram.
Hope this helps.
Jan 10, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore Elite Drawer Dishwasher leaking
Leaking Dishwasher
Jun 29, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwasher leaking on floor
Leaking Dishwasher
Feb 26, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Leaks under left hand side of door; I've installed 2 new gaskets in last 2 weeks & new float switch; doesn't leak underneath
Check for cracks in the inside liner of the door itself. Seal anything that looks like a potential leak with silicone sealer. I'm providing this advice because you have already eliminated the other possibilities I can think of. If it has a soap dispenser on the door check for leaks around that especially.
Jan 14, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
My kenmore built in dishwasher is leaking out the front
change the door gasket. also check to see if the wall hasn't "sprung out" of position this will always cause leaks if the side walls aren't supported.
Feb 02, 2008 | Dishwashers
Dishwashers Logo
754 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
