Question about Maytag Performa PAV2200
Refrigerator warm compressor doenst run but gets hot
    President:
  • Maytag Master
  • 1,922 Answers
Its either low on refrigerant/freon or your evaporator and condenser coils are coated with dirt
Posted on Oct 05, 2009
Compressor is HOT, coil is not warm
Check to see if the fan is running down in the back by the compressor, if it isn't put a small fan back there blowing on the compressor, also make sure the compressor is running you can unplug it and block the fan by the compressor wait a few minutes and plug it back in so you can hear the compressor to see if it is running. if it hums and then clicks you probably have a bad relay and overload assy.
Mar 19, 2014 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
7 year old refridgerator not getting cold enough. Thawing in freezer. Should the condenser be hot/warm to the touch? Is there a re-set?
The condersor coil will be very warm to hot..not so much so it will burn you, yet very warm..the things that will make it very overly warm is if its clogged with dust or the condenser fan motor isnt running all the time the compressor is on. But it will normally be warm all the time the compressor is running..that heat is whats being removed from inside (the way refrigs. work is they remove the heat so when the heat is gone only cold is left)
GENE
Sep 04, 2011 | Kenmore 56983 Side by Side Refrigerator
My side side frige is warm to the touch in the middle
Getting warm around the door is OK but getting hot around door indicates a restriction of the airflow below your refrigerator. The compressor produces hot Freon that is pumped out the discharge side of compressor. On many refrigerators the gas goes to the yoder Condenser Loop first and then cooled by the condenser fan motor before going to the freezer section as a liquid.
Anything restricting that airflow will cause the yoder loop to get hotter. Example a defective condenser fan, dusty conditions below refrigerator or room temperatures way above normal for a kitchen or room inside your home. Insure fan stays on when compressor runs because a defective condenser fan does not always stop when defective. Most refrigerators work best with room temperatures in mid 70's to middle 80's. Making sure that airflow is good, fan's stay on with compressor and room temperatures stay in the normal range is important to keep those temperatures lower in the yoder loop. If helpful please rate this solution, Thanks Sea Breeze
Jun 28, 2011 | Kenmore 53642 / 53644 Side by Side...
Fridge compartments too warm
There are several possibilities on your model. Compressor start components and Adaptive defrost Control. I would like you to pull away from wall and unplug , rempove the cover over compressor and feel the compressor to tell me if warm, hot or too hot to keep your hand there, Waiting for your response, Sea Breeze
Mar 27, 2010 | Jenn-Air JCD2389G Side by Side...
My fridge compartment and freezer compartment is warm. i dont know alot about fridges, so please dont be too technical with me. and its a very old model, 106.769830 E92812566
If both compartments are warm, this means that the compressor is either not running or is running and not circulating the refrigerant. We need to know if the compressor is running. Its the black can looking thing behind the refrigerator at the bottom with copper tubes going to it. If it feels cool to the touch it is not running. If it is warm or hot, it is running and not pumping. If its not running it may be a problem with the thermostat, the defrost timer or the compressor itself. If it is running and hot but the fridge isn't cooling, it may have a leak or a bad compressor or relay.
Feb 20, 2010 | Refrigerators
It started getting hot instead of cold
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Refrigerators
The compressor is running but it doesn't seem to be circulating refrigerant
hi there....locate the high pressure pipe (small diameter pipe)...touch it by hand and feel is it cold....warm.....hot............
cold.......compressor running but no ressure......change comressor
warm.....compressor running....low in gas or internal gas leak..try recharging system may not be repairable
hot.....compressor running.....blocked system....usually not repairable
regards Sir Galahad
Aug 13, 2009 | Frigidaire FRT17G4B Top Freezer...
Inside of fridge is hot. everthing is spoiled
How to check stuff>
Jul 12, 2009 | Magic Chef Refrigerators
The dividing wall between the freezer compartment and refrigerator compartmant is very hot to the touch , use to be warm now almost to hot to touch. mod. #106.56539400
the condensor fan by the compressor is not running. this fan cools the compressor and condensor coils. if it does not run then the mullion (center between frzr and refrigerator side) gets very hot
Jun 24, 2009 | Refrigerators
Freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Aug 20, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Washing Machines Logo
56 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
