Question about Refrigerators
GE Monogram ZFSB26DRSS- water dispenser problem
I changed the filter and water stopped coming out of the dispenser. I made sure the line was clear. The solenoid appears to be working because when I press the dispenser in I hear a noise like it wants to give water but nothing comes out. I disconnected the line under the door and when I turned the water on nothing came out. The line is not frozen in the door as I ran trimmer line up it to the dispenser. Could it be the filter assembly? If it were the solenoid now would I know?
Thanks for your help.
Joe
    President:
  • 1,185 Answers
Normally filters have small plugs in them to stop dirt getting into them during storage
Did you remove them before installing the filter?
Posted on Oct 05, 2009
  • 4,070 Answers
Disconnect the water line at the water inlet valve on the back and try the dispenser to see if water comes out there and see if you hear the valve work. If the water comes out here then the problem could be the filter. The mesh screen in the water inlet valve could be stopped up. Disconnect the water supply line to see the screen. You may have to remove the cardboard backing to see the valve on the back of the freezer.
I have a zfsb26dnd ss GE Monogram with a Dispenser board dead. ordered a new board and same result, ordered a new main control board and still nothing has changed. what else could I check or change?
You changed the main control board---is that the main mother board on the outside back wall of the refrigerator???? If not then the mother board may need changed. Part number WR55X10942. Just about every part of the refrigerator operation runs through that board. If you did change that already I would look for possibly a bad wiring connection to the dispenser system. There is usually wiring and plugs going through the hinge area of the door with the dispenser in it. some are at the top hinge some at the bottom depending on model number.
Jun 10, 2015 | GE Monogram ZFSB26DRSS Stainless...
GE Monogram water dispenser slow to stop after changing water filter
bleed out at least 6 to 8 glases of water there might be a granuale of debris in the water valve and its not letting the diaphram close properly
May 14, 2012 | GE Monogram ZISS420DRSS Stainless Steel
Water dispenser runs very slowly. it doesn't seem to run slow to the machine, just through it. Is there an easy way to check the line? also, I read that there was a water reservoir somewhere... should I...
The filter may be the cause of the slow dispenser. They don't last forever.The inlet screen to the water solenoids where the water line connects to the fridge may be partially blocked. Heat from the night lite bulb can deform the plastic tube at the dispenser outlet and restrict the flow. Check all of the above and you'll find it.
Oct 31, 2017 | GE Monogram ZFSB26DRSS Stainless...
If it's not the filter, then the water valve is most likely defective
Oct 30, 2017 | GE Monogram ZFSB26DRSS Stainless...
Water dispenser has stopped working. Ice maker still works and I've changed the water filter. Still nothing
There are two solenoid valves in the rear of the refrigerator. One that controls water for ice and one that controls water for door dispenser. If the water is not coming through when the button is pushed then have the proper solenoid valve replaced and enjoy. Hope this helps. good luck.
Jul 18, 2009 | GE Monogram ZISS480DRSS Stainless Steel
No water from Water dispensor
Have you checked your water valve? I dont have your model number but you could have what you call a double water valve and one side of it may be out, alternately you may need to change your water filter if you havent done that yet. I have seen were the water stops dispensing first and then stops making ice. have you changed the filter lately? If not change it then if that doesnt work check water inlet valve...
May 12, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
G E Monogram side by side refregerator ZISB420DMC
I'm just a home owner, not an expert. Could be a frozen line. I think GE has had problems with this. I think they've retro-fitted their doors with better insulation that prevents the lines from freezing.
Jun 23, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Monogram water flow problem
common low flow is a kinked line or a bad water valve, the solioid valve has a filter that may be dirty. then go from there
Jun 11, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Ge monogram water line
the water dispenser does not dispense water, although i can hear the motor running, but water is reaching the ice maker.
any tips?
You may have a clogged water line or filter something blocking the flow of the water or you may have to replace the filter or a water line – it may have a defective sending unit / pump and it would be wise to check it out with a regular service tech and to also check your owner’s manual for troubleshooting.
Apr 14, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
Refrigerators Logo
333 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
