Question about Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand
Kohler 84499 1B1x conversion kit instructions say:
Kohler Rialto k3402 toilet
p.3 Rialto: replace the flush valve
p.6 rectangular overflow: do not need to replace the flush valve
Huh?
robocop
  • 90 Answers
SOURCE: Kohler Cimmaron Toilet Flush
You might want to check the flush cylinder, to see if it has water in it. It has to be water free, that way the air in it, lets it go down easier, during fill up.
Posted on Jan 23, 2009
  • 659 Answers
SOURCE: Toilet will not flush
It sound like you have debris caught in the fill valve. Remove the top where the washer is and put your hand over it and slowly turn the water on to flush the fill valve. Replace the washer with a new one and then replace the top.
If you have the old ball and **** style, replaceing the diaphram is harder so I would recommend replacing it with a fluidmaster fill valve. Hope this helps.
Posted on Apr 06, 2009
phmaddnes
  • 24 Answers
SOURCE: Running toilet
Mine does that also, here's what I found.; I am on a well and occasionaly sand gets caught in the valve thingy... Take the tank lid off, turn the arm that attaches to the float assy. 1/4 turn towards the back of the tank and take it out. Rinse off the gasket and pin as well as inside the hole. Reassemble and it should solve your problem.
Posted on Jul 04, 2009
  • 82 Answers
SOURCE: Kohler Rialto flap valve leak
if the flappper isn't closing, there is no suction AKA a clog perhaps.
Posted on Sep 03, 2009
co7196
  • 3433 Answers
SOURCE: I cannot tighten the toilet seat on my kohler 3386
Give Kohler a call AFTER you read the instructions thoroughly. Good Luck, seriously.
Posted on Nov 09, 2009
I have Kohler 3386-6 Rialto Skylight Round Front Toilet problem is that tank filling is very-very slow, perviously it used to fill in few seconds now it is taking 15 min. please let me know how can...
There is a screen @ the inlet to the vavle where the water connects that may be plugged or contact Kohler they will send you a repair kit for the fill valve.
Dec 12, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
After flushing my Kohler 3386 Rialto Toilet the top of the valve assembly shoots water out while refilling the tank wich hits the tank top and leaks down the front. What do I need to do to fix this? ...
sometimes removing the 3 or 4 screws that hold the top of assemble and separating the assemble will dislodge debri..and adjust the seat so that the water comes out of the small tube into the overflow tube like it should.
Nov 25, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
I have Kohler toilet ...I believe it was a Rialto model....the numbers inside the tank are T33 K2402P3 ...
picture is of a kohler rialto
looks like you can get the parts or retro fit newer kohler flush parts
ring around for a plumber or kohler toilets seller that can supply kohler cystern parts
Apr 28, 2017 | Home
Can't install new Kohler rialto Flush Value
First things first, remove the fill valve, and the flush handle mechanism. This will give you plenty of room to work with the flush valve. Before installing flush valve lubricate tabs with plumbers grease. Now put on a pair of work gloves, pushed down very hard and turn the tabs should slide easy because of the grease. Remember do not alter the gasket, the gasket needs to be compressed to do its job. I know removing the fill valve and the flush handle seems like a pain, but there is no way to get your hands in the proper position to install the flush valve assembly.
Apr 25, 2010 | Kohler K-3386-0 Rialto one-piece...
Bowl does not fill after flushing
Check the fill line in the tank and make sure it is connected from fill valve to overflow tube. After you flush the toilet it fill's the bowl and tank.
It should be a line about 1/4 ' in size coming from fill valve to overflow tube.
Dec 28, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
We replaced the toilet kit about 6 months ago and now the toilet runs even when the bowl is filled? What can we do to fix it.
There is either a screw on the top of the fluidmaster, or the float can be screwed out further. If it has a screw on top of the fluidmaster, screw it in to make the valve shut off earlier. Keep adjusting and flushing until it shuts off before it overflows. Hope this helps...
Oct 13, 2009 | Kohler K-3386-0 Rialto one-piece...
Valve adjustment
You need to replace the flapper and you will need to purchase one specifically for the Kohler toilet. I have the same toilet and tried using a generic flapper and from experiance, it didn't work until I bought the correct one and I'm a plumber! Have a great night.
Apr 01, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
if so cut 1/4 inch off the bottom of round part of flat valve
Feb 23, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand Logo
1,182 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
