Fujitsu PDS4241 W Flat screen TV. The Flashing red on/off light indicates a voltage problem. Does that problem exist in the Primary or Secondary power supply board.
  • finamore Oct 06, 2009
    I plan on replacing the secondary board. Will let you know how that works.
  • 1,889 Answers
Secondary but, check for a bad fan first as this is usually caused by an overheat problem
Posted on Oct 06, 2009
  • 3,267 Answers
It is in secondary circuit which is also known as the high voltage circuit. Here very high voltage is created to enable the display unit to function properly.
Either some capacitor or IC, whichever is damaged. If you are familiar with repairing electric goods, then try to find out the exactly what is the reading and then check the values of components, like diode, transistor, etc needs to be pe[laced. If still under warranty, make full use of it. Else get the address of their authorized service center & get it repaired from them.
IMP: if the probleam leads to changing the display tube, it will be cost effective in buying a new TV...............sodeep
Posted on Oct 05, 2009
No 3.3 volts at blon
You need a new main board or a service of the existing one.
For 32'' models probably a replacement will be easier.
Feb 25, 2014 | Sanyo DP32649 31.5 in. TV
My WD- 73727 dont turn on
Helllo
Will you please send me some more details about the fault? The description you have given here is very short to understand. Do the standbylight at the front of your TV lights up? Do you hear a small 'click' sound soon after you switched the tV's power On etc: Give me more details. OK.
Dec 13, 2011 | Mitsubishi WD73727 73" HDTV
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
Tv will not turn on when tried on either tv or with remote green light flashes 3or 4 times then turns into red flashing light no picture or sound at all.Have tried changing batteries in the remote and fuse...
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Jul 03, 2011 | Panasonic Televison & Video
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor...
Monitor ia having a problem with Voltage filtration... Replace the electrolitic capacitors at secondary side of power board, There are 2 voltages, 12 V and 5V...each of them has few electrolitic capacitors in line, replace them, watch the polarity and all works...Cause of eletrolitic capacitors on secondary side may be the one little capacitor in the primary side, becarefull there is some high voltage out there
Dec 11, 2010 | Fujitsu Siemens Siemens Premium Line P17-1...
My display keeps shutting off five minutes after starting to watch TV- the sound continues, but the screen is black and the red warning light flashes
Please check the sequence in which your warning light flashes.
I will tell you what might be the problem according to the fashing of warning light,
If,
Flashing repeatedly --- Improper voltage supply
Flashing once --- Malfunctioning of fan
Flashing twice ---excessive temperature
Flashing 3 time or more--other problem
When flashing occurs please remove the power cord from receptacle and inform your dealer about the flashing sequence.
Thanx
Jul 02, 2010 | Fujitsu Plasmavision 42" TV
Red light flashing...no picture. TV not turning
Probably a failed main power supply. There are at least two supplies; one that keeps the remote function alive continuously and the second that is turned on when the set is ordered to operate. The smaller supply is a low voltage circuit and that is providing your error indication.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
Flashing red light no screen fujitsu plasma
This is a common complaint with Fujitsu plasma displays with a few years age. It is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
Jun 04, 2009 | Fujitsu Plasmavision 42" TV
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
