I forced open my stuck audio tapes and now the doors won't close. I'm told there are no parts available for the FWM575/37 I bought some time ago. I live in Hamilton, Ontario and don't know where to find anyone to fix the tape decks. Help!
  • 71 Answers
England yes can help parts here whats the name of the deckis it a philips
Posted on Oct 10, 2009
Tapedeck will not close
What model and is there something in the way of the tape. Often times if a belt fails or a cam system gets stuck the head base can not
retract and then the door can not open or close correctly- do not force it as the parts will break.
Feb 24, 2014 | Sony Audio Players & Recorders
I have a Craftman Garage Door Opener Mod#139.53650SRT. It closes completely then goes back up. I replaced the sensors @ the sides of the door to no avail. I have tried to adjust the up and down on the side...
I agree with the closing resistance may be set incorrectly, all openers have a safety feature that senses if something is keeping the door from closing, this is back force, you set the sensitivity at the back of the opener motor control, it is a little dial, reduce the setting just enough to stop the door from kicking back open when it closes, I had this very same problem with my craftsman and this adjustment fixed it.
Oct 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
2006 Honda Odyssey electric door won't close
there is a slide door control module for each door
Jan 28, 2013 | 2006 Honda Odyssey Touring
Pinch roller stuck in "up" position, eject button won't open door
The very first mistake is to pry a door open. That damages them. You are never to do that. The correct way to get a tape out is to open the unit up and find out why the tape is stuck and then take action to release the door in the normal way- usually it is a loose belt or defective cam motor. As to the Pinch roller there are slide plates and even some pinch rollers had lubrication on them so that may have dried leaving you with a stuck part. The normal order of business is the find out what is stuck and then take action to clean and lubricate the mechanism to return to normal function. The problem with some Pinch Rollers is that there may be a particular spot it needs to be set at. This is true if it has a guide fitted to it. Then you will need either a jig or mirror tape to be able to set it correct again. I can not give any further advice without seeing the unit but this should get you started.
Dec 03, 2012 | Audio Players & Recorders
JVC Camcorder Tape door stuck
michanical dis arrange inside the tape socket
Mar 20, 2010 | Video Cameras
One side of the door on my Fuji s300 where the card goes in has broken off. The other side is still intact. Right now I keep the door closed with a piece of duck tape. Can the door be replaced and where...
Didn't fix the problem. Part not available so duck tape will have to do until I'm forced into another camera. I like this camea but both Fuji's I purchesed had the same problem with a door. The other was the battery door where the tabs that kept the door closed chipped off so the door would not stay closed.
I will not purchse another Fuji.
Dec 02, 2009 | Fuji FinePix S3000 Digital Camera
Cassette door stuck closed
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Nov 02, 2005 | Aiwa NSX-A115 Shelf System
82 people viewed this question
 Grubhead
Grubhead
