Question about HP Color LaserJet 5500 Printer
Our IT Dept replaced the image transfer kit in our HP5500 but did not reset the display, now the display is saying replace transfer kit and will not operate. How do I reset it?
  • 81 Answers
With the power on, press the down arrow button until the display reads " Configure Device" menu. Press the Select button and using the down arrow button, scroll through this menu until the display reads "Resets" and press the Select Button. Then press the down arrow button again until the screen reads "Reset Supplies" and press Select button. Once you get to this menu this is where you can reset the fuser and the Transfer belt count
Posted on Oct 13, 2009
To printer 4025
you need to go where it says Service then input that code and scroll to reset the belt. ( this only needs to be reset in Service mode when changing before the counter says to.)
Dec 05, 2016 | HP LaserJet Office Equipment & Supplies
Rioch spc320dn Maintenance Kit #406794 It say replace the imager? What is the imager?
In a laser printer the 'Imager' is probably the same thing as the 'Image transfer drum' - this cylindrical unit has the Image of the page to be printed electrostatically set by the laser - this electrostatic image is then transferred onto the sheet of paper and electrically charged toner sticks to the page to form the image - the fuser then heats the paper and toner to fix the image and stop it smudging - The Image Transfer Drum will only be able to carry out this function a certain number of times and will need to be periodically replaced - in a business setting this could be within 1 - 2 years, in a home user setting it could last much longer - It depends on the volume of pages printed during the printer's working life
Feb 17, 2015 | Ricoh Aficio SP-C320DN - 26 PPM Color...
How 2 replace a hp5500 transfer kit?
Go to www.feedroller.com and locate your model. This website also has a icon for maintenance kits.
Aug 01, 2014 | HP Office Equipment & Supplies
How do I replace my HP Color LaserJet 4700 Image Transfer Kit? I don't have the manual for it.
Replace the ETB when a REPLACE TRANSFER KIT message displays on the control panel.
1. Turn the printer off.
2. Open the top and front cover.
3. Lower the ETB by pulling the green handle at the top of the unit downward.
4. Press the small blue latches located on either side of the bottom of the ETB and lift the unit out
of the printer.
5. Install the new ETB.
6. Close the front and top covers.
Apr 11, 2011 | HP LaserJet 4700 Printer
Our Dell 5110cn stopped working and the 'diagnostic' said to replace the transfer roller. I had purchased a Dell Imaging Drum and replaced that. I believe it has a transfer roller as part of the Imaging...
Dell sells the drum & transfer roller a kit, but there are 2 different parts to it, the drum & the transfer roller & they do not look the same. Replacing the drum does NOT replace the transfer roller. We've had a 5110cn for 4 years, I've replace both of these parts & the fuser unit several times.
May 07, 2010 | Dell 5110cn Laser Printer
How do i reset the transfer kit for HP LJ 4700
with the power on, press the down arrow button until the display reads " Configure Device" menu. Press the Select button and using the down arrow button, scroll through this menu until the display reads "Resets" and press the Select Button. Then press the down arrow button again until the screen reads "Reset Supplies" and press Select button. Once you get to this menu this is where you can reset the fuser and the Transfer belt count
Oct 06, 2009 | HP LaserJet 4700 Printer
K image drum
Go to
menu>Configure Device>Print Quality>select Full calibrate now
once it's completed then run following action:
Menu>Configure Device>Reset>Reset Supplies>New transfer kit>yes
you are done but it works if there still remaining bit transfer kit if its run out then not gonna work.
Good luck and rate all answers.
Mar 31, 2009 | OKI B4600 Printer
Installing a Transfer Kit
i got this info from www.partshere.com site - they have most service notes for hp printer and sell most hp parts, including maintenance kits. I hope info. bellow is helpfu.
Replacing the transfer unit
Replace the transfer unit when the printer control panel displays REPLACE TRANSFER
KIT
. The image transfer kit contains a replacement transfer unit for this printer.
WARNING! Remove any jewelry or any other metal items from your body to avoid electric shock.
1. Lift the front door handle and pull down the front door.
2. Grasp the right blue handle. Press and hold down the blue button. Slightly lift the right
side of the transfer unit.
3. Grasp the left blue handle and lift to remove the transfer unit from the printer.
4. Using handles, remove the new transfer unit from the bag. Use the blue handles on both
sides to hold the transfer unit.
5. Place the new transfer unit on a flat surface. Remove the orange shipping locks.
6. Guide the left side of the transfer unit into the front door of the printer. Insert the two
pegs on the left side into the holes, and then lower the right side into the door.
7. Make sure that the blue button on the right blue handle has released (popped up). If the
button has not released, grasp the right blue handle and pull the transfer unit toward you.
8. Firmly close the front door.
9. After the front door is closed, after a short time, the printer control panel displays the
message NEW TRANSFER KIT.
10. If the message NEW TRANSFER KIT does not appear, you must reset the transfer unit
count. To reset the transfer unit count, go to step 11.
11. On the printer control panel, press to highlight YES, and then press to select it. The
transfer unit count is reset, the printer recalibrates, and then the printer is ready to use.
NOTE If the old transfer unit was not at end-of-life when it was replaced (for example, if it was
damaged), the transfer unit count must be reset using the printer control panel.
Replacing the transfer unit when it is not at end-of-life
If you replace the transfer unit when it is not at the end-of-life, for instance if it is defective,
you will need to reset the transfer unit count and then calibrate the printer, through the
control panel.
To reset the transfer unit count, do the following:
1. Press MENU to enter the MENUS.
2. Press to highlight Configure Device.
3. Press to select Configure Device.
4. Press to highlight RESETS.
5. Press to select RESETS.
6. Press to highlight RESET SUPPLIES.
7. Press to select RESET SUPPLIES.
8. Press to highlight NEW TRANSFER KIT.
9. Press to select NEW TRANSFER KIT.
10. Press to highlight YES.
11. Press to select YES.
To calibrate the printer, do the following:
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
The transfer unit count is reset and the printer is ready to use.
see pictures on link:
http://www.partshere.com/Models/Q5990A/CLJ_3550%203500%203700Installation_n_config.PDF
Apr 18, 2008 | HP Color LaserJet 3500 Printer
Squeaking noise when printing
Probably, but you?re going to have to try to isolate the problem a little better. Typically this would involve removing side panels and such; however, you may just have a faulty consumable like a toner cartridge, fuser or more likely the transfer kit. I typically try to isolate the sounds location then try replacing some of the consumables in that area one by one. In your case if you can?t isolate the location I would start with the transfer kit since that has a greater chance of making noise. Let us know what you find out and please don?t forget to rate the posting when we?re done.
Feb 02, 2007 | HP Color LaserJet 5500hdn Printer
HP Color LaserJet 5500 Printer Logo
569 people viewed this question
Seeker5211
Seeker5211
