Question about Jenn-Air Cooktops
What is a bottom vented cooktop - Jenn-Air Cooktops
  • Jenn-Air Master
  • 8,404 Answers
There is a fan that sucks DOWN like a Jenn-Air cook top. There is no hood usually over such a stove. Usually the suction for the vent is between the burners. I think the air can be exhausted through a filter back into the room or to the out of doors.
The salesman didnt explain this to you???
I hpe this answers your question
Posted on Oct 05, 2009
Downdraft vent unit is stuck halfway.
You'll have to remove it and manually reverse the drive gear. Hopefully, it didn't get stripped.
May 07, 2009 | Thermador SGS36GS Gas Cooktop
Jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
Feb 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Draft
Someone suggested the flapper needs replacing.
Thanks for your help.
Jan 18, 2009 | Jenn-Air JED8430 Electric Cooktop
Vent Cleaning Problem
Hello.
Down drafts are one of the biggest pains in the neck to work on, because one has to get underneath the cook top, and remove the duct, then the blower motor, and then the cover that is over the part that goes up and down. That is if the contractor who put it in didn't build shelves around it or put a bunch of drawers in front of it. So there you have it. It is not easy to clean it. You have to be prepared to disassemble it and try and put it back together properly. One time a customer paid me to have me completely dissassemble the inside of her refrigerator because some bad fish had leaked into everything and she wanted to clean it. You could always do that.
Nov 30, 2008 | Jenn-Air JED8230 Electric Cooktop
Cold air draft
the only way is to block off/check the flapper., if your not going to use for the winter you can disconnect the vent from under the cabinet temporaily and close off there till you can gain access to check outside grill
Nov 25, 2008 | Jenn-Air JED8430 Electric Cooktop
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Gas cooktop vent code
planning to install a 30" stovetop natural gas.need to know if i need a vent to the outside, it has 4 burners
Nov 07, 2007 | Cooktops
Installation of new electric cooktop
If you're talking about a downdraft style cooktop, you will just need to measure the discharge vent diameter and shape and match that up. Not all are the same shape but most are 6" diameter
Apr 22, 2007 | Whirlpool 30 in. RC8700 Electric Cooktop
Cooktops Logo
127 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
