Question about Horizon Exercise & Fitness
HORIZON T81 LUBE BELT-WHERE DO YOU LUBE THE BELT & WHAT LUBE DO YOU USE?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message “LUBE” or “LUBE BELT”. The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness.
Without a good treadmill belt lubricant, the deck can begin to wear down early and the increased friction will mean that your belt will not last its full lifetime. If possible avoid using silicon based treadmill belt lubricant or an oil lubricant, and use only the treadmill belt lubricants that are specifically recommended by the manufacturer.
Follow these steps to lubricate your Horizon T81--
• Turn off the treadmill with the on/off switch, and then unplug the power cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable marks on both sides of the frame and note roller position). Once the belt is loosened, take the bottle of lubricant and apply it to the entire top surface of the running deck.
• Tighten both rear roller bolts (matching up the marks for proper position) to original position.
• After you have applied lubricant, plug in the power cord, insert the safety key, start the treadmill and walk on the belt for two minutes to spread the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding ‘STOP’ and Speed ‘+’ buttons for 5 seconds.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 05, 2009
What does lube bell mean
Either your treadmill has a typo or....well, it's LUBE BELT.
Go here: http://www.horizonfitness.com/support/customer-support
Download the manual for specific model and it will describe how to lube the belt. There may be a RESET procedure required to turn off the message and turn on the treadmill.
GL,
Td
Aug 12, 2014 | Horizon Fitness Horizon T90 Treadmill -...
My Horizon T80 treadmill is emitting a smell after operating a while not an electric smell but a rubber chemical smell
How old is the walking belt? When was it last replaced? How many miles are on the belt. Seem like your belt and deck is worn.
Jan 01, 2014 | Horizon T92 - Treadmill
Code 701 06 comes up
I have a T91 and first had the Lube Belt error. After lubing the belt and upon turning the unit on while holding the Stop (Not necessary according to instructions by horizon but I did it while powering up anyway) button down, the 701 06 was momentarily displayed. The unit then displayed the Lube Belt warning again. Lemme know if you hear anything, I am working on it.
Burt
Nov 17, 2013 | Horizon Exercise & Fitness
My Horizon CT 7.0 treadmill slows down when i step on it
LUBE THE deck belt and rollers bearing . This happen because you must lube about 150 miles aprox. See the video and fix it. However if the problem persist. Time to replace the old board deck.
God bless you
Jan 25, 2013 | Horizon CT7.0 Motor Control Board
Treadmill
Dear Sir:
PLease LUBE the deck belt, is possible the deck is worn!
2) Test the drive belt too 3) Test and lube the roller bearing 4) Lube the bearing main motor. All this parts is subjects to maintenance, see your instruction manual.
Run the software calibration for diagnose, and troubleshooting.
sincerely. God bless you
May 03, 2012 | Horizon Fitness Horizon T101 9 Program...
What is meant when it shows "lube belt"?
You need to apply lube between the walking belt and the black deck surface. Most manufacturers use silicone lube. We sell a lube kit for our treadmills that includes an applicator and a bottle of liquid silicone.for around $20.
Feb 09, 2011 | Horizon Fitness Horizon T103 Treadmill ...
Lube Belt displays on digital display how to reset or where to lube the belt.
The message "LUBE" or "LUBE BELT" scrolls across the console display window. The treadmill will not operate while the message is displayed.
Reset the console by pressing the STOP and SPEED “+” or “^” for five seconds.
Jul 28, 2010 | Horizon Exercise & Fitness
HOW DO I LUBE MY HORIZON T81 TREADMILL
Your lube goes between the walking belt and the deck( the board under the belt). Apply lube as close to the center of the belt as possible then walk at a slow speed to spread lube evenly.
Jul 14, 2009 | Exercise & Fitness
Exercise & Fitness Logo
1,521 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
