Question about Dishwashers
The Hotpoint Aquarius DF62 Dishwasher detergent draw has come off, how do you refit and which spring goes where
Help! how to you put the spring back on the detergent compartment on Hotpoint Aquarius DF 62, any help would be appreciaed,,,,
Posted on Jan 29, 2011
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
Need to remove panel to access spring on detergent dispenser lid on hotpoint dishwasher
is several screws on front door (inside side), take them out carfuly, because is where the door spring is connected, and you must reach on the detergent dispenser mecanism.
Nov 06, 2010 | Hotpoint Dishwashers
Cloths are smelly even after wash on Hotpoint WD440 machine.Any suggestions
hi you may want to try this stuff , its american i think but now availabel in britain ( ebay)
affresh washer cleaner
Aug 22, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WM62 bearing noise how to change it
Hello,remove all the surround screws from around the door glass then gently lever the 2 halves apart,remove the old hinge,and re mount the new one along with the plastic bearings refit the screws,refit the door to the front cabinet.
Thanks
May 23, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Dishwasher door won't close
OUrs did the same, it was a tiny spring that needed replacing. We just turned off at mains, unscrewed front and took out the unit. Took broken spring out and found one at our local DIY shop. fitted and put back in. ALOT cheaper than replacing the unit!
Oct 20, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius WF440 Repalce Door Seal
no need to remove front panel
remove clamp that holds boot to cabinet and peel away boot
take top off
undo clamp that holds boot to tub and pull boot off
lubricate slot in new boot that goes on to lip of tub
starting at top, insert slot onto lip of tub and work your way round in both directions pushing slot onto lip
refit clamp
push door boot onto lip of cabinet and refit outer clamp
test on rinse cycle for leaks (water level is higher
water will be a bit foamy till fluid is washed away
Sep 06, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Fabric conditioner drawer full of water!
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius dishwasher
Oversudsing
This can be due to using a laundry or handwash detergent instead of a specific dishwasher detergent instead. It could also be due to excessive amounts of rinse aid in the dispenser or certain food soils that contain a high level of protein such as eggs.
Oct 08, 2007 | Hotpoint 24 in. FDW60 Free-standing...
The reason for this (foaming up) is because you are using a 4 in 1 detergent and also using rinse aid (or maybe you have just topped up rinse aid and spilt some)
If you are using 4 in 1 tablets, do not use rinse aid as this causes foam.
Hope this helps
Sussex engineer..
Please rate my help. Thannk you
Oct 08, 2007 | Dishwashers
Dishwashers Logo
371 people viewed this question
Top Dishwashers Experts
