Question about APC Symmetra Power Array Rm 4Kva Exp To 6Kva (MPN-SYH4K6RMT-P1 KIT) UPS System
Searching for a Symmetra Power Array...
Web/SNMP Management card keeps searching for a Symmetra Power Array... looks like intelligent module is damaged... at the symmetra LCD screen there is a message saying Programming V1.0. The intelligent module has 3 LED's from left to right, first LED is orange blinking 3 times then stops for about 10 secs. then blinks again 3 times. Second and third Green LED's always on.
Two power modules, all FAN's are ON. Intelligent module : SYMIM3 Redundancy module : SYRIM3
2 Suggested Answers
  • 14 Answers
SOURCE: I Have an 80KVA APC
Hello
Please clarify. If you change the suspected module position and the module is not working, then the problem is with the module. If you replaced a working module in the non working module position and it does not work then there is a problem with this particular slot. Normally you would replace the faulty module with a working one in its slot and things would be clearer. I do not understand well the way you describe the problem, however each module has a micro-switch on the side which activate the start up of the module. have a look at it. i hope this will help
Posted on Jun 11, 2011
What Web-based Management Features Do Switches Excluding the S1700 Support?
Table 1 lists the web-based management features supported by S series switches.
Table 1 Web-based management features supported by switches Category
Function System management Upgrade, patch loading, PoE, DNS, stacking, viewing log files, and setting the system time, SNMP parameters, and EasyDeploy parameters
NOTE: Switches in V200R002 and later versions support SNMP and EasyDeploy parameter configuration. Interface management Viewing/configuring basic interface attributes and viewing statistics on an interface Service management VLAN, MAC address, STP, voice VLAN, DHCP, ARP, VRRP, and IGMP snooping ACL management Creating/modifying/deleting ACL rules and effective periods QoS Priority mapping, traffic policy, rate limit on an interface, traffic shaping, and congestion management Route management Viewing IPv4 routes, configuring static routes, and setting the preference of static routes Security management Port isolation, static user binding, AAA, 802.1x authentication, and MAC address authentication Tools Ping, Tracert, and VCT S2300 Switch Thunder link com
Feb 09, 2017 | The Computers & Internet
What parts are used to preform a tune-up
First you need a tech that is qualified and has experience in Annual PM's on this type of unit. Symmetra is a module type unit. there is hardly any "tune up' to do to this unit. Test the batteries and insure all modules all ok, this includes the intelligent modules that pull out. Review past alarms that have been recorded and insure that no major alarms are present. Do a battery test from the display interface. Clean the area around the UPS.
Aug 31, 2012 | APC Symmetra Tune-UPS technical support -...
THE UPS HAS TOTALY TURN OFF. NO DISPLAY ONLY WORKS ON BYPAS
Hi.
First open UPS cover check up the battery backup ,power supply area (fuse ,bridge type diode and power transistor) and wiring maybe loose.
Jun 21, 2011 | APC Symmetra - Power array - 6000 VA...
Vreau sa scot driver
hello brother
Looking for Driver Updates?
Update and Fix your Drivers Instantly!
Keep drivers up to date automatically with UpdateMyDrivers. Recognizing more than a million hardware devices, UpdateMyDrivers keeps your system always up to date, guaranteeing the best performance and reliability to your Windows 7, Vista or XP PC completely automatically. The intelligent driver update engine detects outdated drivers, providing a comprehensive report and offering to update the drivers.
http://www.smarttweak.com/umd/details/
or www.ma-config.com
Jun 12, 2011 | Manhattan Mini WEBCam
I Have an 80KVA APC Symmetra PX and one of the power module is not working I already change position with other power module and still not working
Hello
May 09, 2011 | APC Symmetra 12kVA Basic System...
Symmetra LX "Intelligence Module Fault". Does
First calculate the total load of the UPS and then calculate the total load. One of the Intel Module is Primary and one is Secondary. I can't remember exactly which one is primary. Q1. There will be a LED on the INTELI MODULE flashing RED. That identifies the bad MODULE. Q2. You can remove the MODULE, but I recommend you place the UPS in Static Bypass first through the Display Menu. Also make sure the UPS is in NORMAL MODE or already in STATIC BYPASS, the LED's on the Display should indicate what mode its in. Q3. You can remove the display from the Inteli Module with out harming the load. You just can't do anything with the UPS, as to tell it to Go to Bypass (Static Bypass) or get out of Bypass, check voltages, etc. So order the part first by getting part number on the sticker off the Module, then schedule your shutdown and perform the you maintenance after hours this way you don't affect anything during business. Also don't do the repair on a Friday due to the fact its weekend and APC/Third party UPS companies will charge you a lot to come out in the weekends. FIRST DO THIS PLEASE- GET THE MANUAL FOR THIS UNIT!!!! And READ IT FIRST!! Find in the manual where it walks you through putting the UPS In bypass (Static Bypass). Follow the manual, My way of doing is to READ TWICE, OPERATE UPS ONCE!! This has help me not dump any loads. My suggestion to you is to check if unit is in Bypass (static Bypass due to the faulty module. If it is on Bypass then all you need to do is follow the procedures to place UPS in External Maintenance Bypass. If UPS is in Normal mode but with Alarms and Beeping, then Navigate through the display and find the BYPASS Mode. Then hit enter Yes on the BYPASS MODE, it will ask you again if you want to "Place UPS INTO BYPASS. Hit YES. You will hear it click. Your LED on the display should Light UPS Solid "BYPASS LED ON" AGAIN Please keep referring to the MANUAL. Once your in bypass mode (Static Bypass) then you can operate the External Bypass Switch on the bottom of the UPS. That is the Maintenance Bypass Switch. This isolate the UPS completely and your load never see's the transfer from Static Bypass to External Bypass, Because its a MAKE BEFORE BREAK System. (Make the power before Breaking the Power) Sorry to get down to simple terms, but when I work on a UPS its personal due to the fact you are responsible for the all that is on the OUTPUT of that UPS. Once on External Bypass, You can now do you module swap. Turning the UPS back on, Please follow place UPS back On Line in the UPS Manual. Also in the Diagnostics, off the display of the unit, it also identifies what module is bad including the Power Modules to the Battery Modules.
Nov 03, 2010 | APC Symmetra Tune-UPS technical support -...
I have a Symmetra LX 16000 , and ups sen me the message ...Critical - UPS A main intelligence module fault exists.. code 0x0203.
Hi Scabcmx,
Without knowing the full model number of your UPS I cannot go into specific details fully for you.. but a good test with any 'intelligence module fault' is to re-seat the module and run a self test. If the fault remains then your intelligence module is bad and you will need to acquire a new one to replace the faulty one. This can all be done 'on-line' and you should not have any downtime... assuming there is a redundant intelligence module in the unit which is normally the case. This will clear the fault.
If you would like more information give me a call: 407.380.9200.
Oct 12, 2010 | APC - UPS - Matix/Symmetra Enterprise UPS...
Symmetra LX16000,5.93kva; Problem;Alarm indicating power module fault.
Hi Akortic,
Without knowing the full model number of your UPS I cannot go into specific details fully for you.. but a good test with any 'power module fault' is to re-seat the module and run a self test. This only applies if you have an extra/redundant power module to support the load. If the fault remains then you have a bad power module and you will need to replace it as soon as possible. This can all be done 'on-line' and you should not have any downtime... assuming there is a redundant power module in the UPS. This will clear the fault.
Nov 13, 2009 | APC - UPS - Matix/Symmetra Enterprise UPS...
APC Symmetra Power Array Rm 4Kva Exp To 6Kva (MPN-SYH4K6RMT-P1 KIT) UPS System Logo
90 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Electro Med Services...
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
