Question about ASUS P4P800 Motherboard
Dead Mother board.out of 60 machie built in 2005,now dying.
My Gigabyte Mother Board shows some time Load Optimized Defaults then boot / Load Optimized Defaults then reboot / enter BIOS. How to fix it?
Two things come to mind first. Number one would be making sure you have the most up to date bios. Number two would be that maybe the motherboard battery is dying/dead and isn't holding enough charge to after being shut down to save the option you selected.
Apr 11, 2014 | Gigabyte Technology Gigabyte GA-H61M-S1...
My Dell Optiplex Gx 620 isnt turning on..... No lights no sounds is it the motherboard
Bad power supply first, or just the switch. The mother board will keep it from posting, but lights should come on. a bad power supply or switch it will be dead like fred.
If your handy there are many tutorials on diagnosing a power supply on the internet. Usually when it is the mother board there will be a few beeps or flashing lights then a shut down, or frozen pc on boot then death.
But all these symptoms can come from a dead or dying power supply.
http://www.overclock.net/t/96712/how-to-jump-start-a-power-supply-psu-test-a-power-supply-and-components Do this at own risk..
Jul 07, 2012 | Computers & Internet
Died. nothing comes on, so not dead drive. switched out power supply, so not dead power supply. the switch on the front - blue led only comes on when plugged in lower right two prongs of 8 (4x4). So, tried...
short power switch pins on mother board, reset bios, short green wire to black wire on ATX connector with all drives etc.. power cables disconnected to test power supply. i suspect you have a dead motherboard.
Jun 20, 2010 | eMachines ET1161-01 PC Desktop
No video signal on computer start up?
if u have built in VGA take off the Rams wash them with some ethanol then dry them with a blow drier then put them back into place and if u dant have built in VGA wash it as well
Jun 22, 2009 | Computers & Internet
Removing files from a dead lap top
If the computer is dead the only way to recover the files would be to remove the hdd & install it as a secondary hdd in another system in order to copy the files. After you are sure all your data is copied you could then either reformatt & keep as a storage drive in other system or remove. You'll need the proper cables as most laptop hdd's just slide into a built in port on the laptop's mb. Hope this helps.
Mar 30, 2009 | Sharp Actius AL27 Notebook
The cpu doesnt start,experts say motherboard is dead
it happens when one of the component would not give the exact dc supply to its component near to each other and its so hard to replace a chips that has been broke down. okay, try this, although its to risky but theirs no other way to test your main board if its still good. if your video card is built in, plug the external video card. if your main board accept AGP or PCI then try them one step at a time. load the memory then try booting it again. if it still has no display bring it to a service center near you ask their assistance to make a series of test to your main board. Im sure they a device to test all the IC's and the chipsets. Good Luck!
Dec 19, 2008 | Intel D915GLVG Motherboard
Bios flash
firstly i want to tell you that every motherbord bios has a unique program to control the devices.
it this bios is fit on another board casing then you try to firstly run the mother board with old bios. then copy the bios code by any flashing tool and then remove this bios and fit the dead mother board bios in the casing then flash it and then update it which file you copy the old one.
then your motherboard perhaps go on with the dead motherboard bios.
thanks
ramesh
Oct 16, 2008 | Intel D865GBF Motherboard
ASUS KBN-E MOTHER BOARD 754 processor 512mb ram
Try plugging the drives into another computer to see if they actually work, ie read discs etc if they do then try swapping the power supply out of your computer.. if this doesn't work then I would say your motherboard is dead. Good luck
Jun 02, 2007 | ASUS K8N4-E Deluxe Motherboard
ASUS P4P800 Motherboard Logo
24 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
