Question about Ovens
The oven light and fan will go on but the oven will not heat up, there is a symbol on the screen of an oven pot but it cannot be removed
  • Ovens Master
  • 3,463 Answers
If the fan is working o/k, then in all probability, it will be the oven element that neesd to be replaced.
Please rate my solution.
Thanks.
Posted on Oct 05, 2009
Fan operating except on fan only setting
Open the oven ,if you are a technician, check the cables for the fan switch and that for the heating filament are clearly seperated .
Mar 13, 2016 | Ovens
AEG double oven/grill stopped working
It appears the oven has shorted out. Try checking the breaker box and see if any switches have been flipped. If this is not the case a new oven is in order.
Jan 24, 2014 | Ovens
Hello, I am having trouble with my built in Zanussi ZBF 360. When I turn the oven on to the fan symbol the 'on' light comes on and when I turn to the required temperature the heating light also appears. ...
If you cannot hear the fan going, then it is possible the fan is faulty, and the element has probably failed as well.
Both these components can be accessed by removing the panel at the rear of the oven compartment
Feb 02, 2011 | Zanussi ZBF360 Electric Single Oven
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
Belling synergie oven grill comes on oven fan comes on all lights are working but no heat in the oven temp 200 setting on the oven symbol all plugs have been checked.
I suspect tha the oven element is faulty.
To access it, you will find it located at the rear of the oven compartment behind a removeable cover.
Hope this helps you.
Dec 13, 2009 | Belling Ovens
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Seems to be taking a long time to cook
To preheat oven just select the temp you intend to cook at and wait until the red light goes out,it is then preheated
Then you can put your food in and carrying on cooking.
Yes you do put it on fan symbol, but make sure it is on the right one , as some ovens have fan only as well as fan and heat.
Plz rate this solution.
thanks.
Dec 14, 2008 | Ovens
Oven not switching on
the f-01 means the oven control is bad. when your pot spilled it shorted out the control board
Nov 27, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
