Question about Tomtom GO 700 GPS NAVIGATION BRAND ONLY $9.95 SHIPPING
Can i connect two pairs of inceiling speakers on my JVC receiver that only has the output for two speakers at the back?
    Scholar:
  • 67 Answers
Sure, just split at the source.
Posted on Oct 09, 2009
How do i connect my JVC screen tv so that i can hear out of my speakers
If your JVC TV has AUDIO OUT outputs on the rear and a provision in the initial set up screen to disable the internal speakers, you can connect to your Yamaha receiver and enjoy improved sound.
Dec 14, 2014 | Yamaha RX-V471 Receiver
Need to know how to hook tv up to prewired home surround system. connections on wall, seakers inceiling
Run the audio output from the tv rca audio output, to any input of receiver and hook your speakers to receiver. You cannot hook up speakers to tv cause its a low level audio output. Needs to be amplified.
Nov 15, 2011 | Televison & Video
When I hook up the rear speakers to my in-wall speakers, I can't get any sound. I have speaker button 1 and 2 selected.
Hi:
you need to clear that you connect wall speakers for font,center or rear (surround) speakers?
Seem you connect for Front speaker.
Rear (surround) speaker will have "rear" mark on the back of your reveiver.
In general you need to select both buttons 1 & 2 then check your speaker wires connect into "output1" or "output 2" hint: each output will have 1 for left and 1 for right speaker. Each Left or right speaker will have 2 connection 1 red color (+) and 1 white color (-). Try to match these colors code for your speakers connection.
Feb 25, 2011 | JVC RX-884V Receiver
Connecting a receiver to a computer
No. That's for connection between JVC compatible units.
Not knowing what kind of inputs your PC takes: if it has only analog RCA-type inputs, run a pair from the receiver's tape out; if the PC has digital toslink (optical) or spdif (coaxial) inputs and the receiver has some sort of digital output, use that.
You could also rig a connection from the tape out, using adapter cables, to the PC's headphone in.
Jan 18, 2010 | Audio Players & Recorders
No volume in TV sound. I have volume in both FM radio, and CD modes.
I presume you mean no audio whatsoever from the TV as a source... If you have the Audio Out of your TV connected with an RCA jack pair to TV Sound In (or any other source EXCEPT Phono) and you properly select that source AND your TV is configured to output its sound to that path, you should have something audible. Perhaps your TV is set to Mute the output when using its own speakers or something like that. My guess is the problem is external to the receiver.
Try connecting something else to the TV input on the receiver to prove or disprove its function.
Nov 20, 2009 | JVC RX-6008V Receiver
How do I connect this subwoofer to my reciever
The simplest way is to insert the sub into the speaker wire run -- connect your receiver's speaker output to the sub input, then the sub output to the speakers.
These are the "High Level" connectors on the left side of your sub.
If your receiver has a subwoofer out (either one or a stereo pair) then you'll get better quality sound by connecting that output to the "Low Level" connector or connectors on the right. If you have stereo, then use both connectors. If your receiver only has one subwoofer output, then connect it to the left (may or may not me marked as "mono" depending on the age of your sub)
Hopefully that helps. If it's confusing, post back questions or post the details (brand and model) for your receiver.
If it's helpful, please hit the Thumbs-Up for me!
Oct 16, 2009 | KLH ASW10-120 Subwoofer
How do i properly connect the wires for a JVC SX-SW5th
Connect the speaker output of the reciever to the input of the speaker. Make sure you connect negative receiver output to negative speaker input and positive receiver output to positive speaker input.
Sep 15, 2009 | Audio Players & Recorders
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Jan 02, 2009 | JVC RX-554V Receiver
I need to set up 4 pair of speakers, two zones. all ceiling mounted.
Okay! all ceiling mounted speakers. I don't know about 4 pair of speakers.Here is the load down:
First pair of ceiling speakers would be left and right front from speaker A or Main output behind your receiver.
Second ONE,but a pair would be connect to the center channel output as your center speaker.
Another pair would be connect to the surround sound left and right(NOT surround BACK left/right.)
Now,you have 5 channel setup at this point,you still need to purchase a power subwoofer to the SUB PRE-OUTPUT behind your Denon receiver.
For Zone two,you would need to connect your other pair of speakers to surround BACK left and right output.
Go to your Denon MENU button,depending on which model you have,some of them will have an on-screen display feature(you would need to have a composite video cable connect from the video output behind your receiver to the TV video input in order to use the on screen menu.)If not,you would have to it view on the front panel of the A/V receiver.
You need to read the detail on how to setup the video and audio as well as distance and DB for the receiver through the menu button.
I will be frank with you,if you are an amateur,Denon is NOT easy to be setup on the first time.
solutiondoct
Nov 06, 2008 | Denon Audio Players & Recorders
Tomtom GO 700 GPS NAVIGATION BRAND ONLY $9.95 SHIPPING Logo
99 people viewed this question
Top Tomtom Car Audio & Video Experts
xxxxxx xxx
Are you a Tomtom Car Audio and Video Expert? Answer questions, earn points and help others
