Question about Motorola Mobility E815
Verizon Screwed my e815
Yes, I have the same problem. I have a Motorola e815 that has always worked perfectly with Alltel service. Since Verizon has taken over, I can't download picture messaging or messages with sound. After numerous visits to the Verizon (previously Alltel) Service Center and calls to Verizon Customer Service, I've been told the problem is with the phone and not with the Verizon network. Their solution is to get a new phone and contract, neither of which I want. I was with Alltel for more than 16 years. Funny.....I had no problems before Verizon took over. AT&T is beginning to look better and better. Any suggestions?
SOURCE: My Golden Motorola RAZR D&G always displays no service !!!!
I have the same problem, displays shows no service and occasionally says invalid battery. Done all the usual things i.e. tried different sim card, different battery. I bought the phone on ebay from Hong Kong. At the moment it is a very good ornament! Help please.
Posted on Jan 11, 2007
  • 7 Answers
SOURCE: Motorola E815
Depending on what is locked, you may find a master reset helpful. If you have time to kill, there are only so many combinations in a four-digit number. It took me less than an hour to hit on it once.
Posted on Jan 24, 2008
Bajanguru
  • 7752 Answers
SOURCE: Motorola V220 wont download picture messages
you need to do a master reset of the phone
menu/settings/intial setup/master reset
Posted on Jul 03, 2008
SOURCE: transferring a phone from Alltel to verizon
4545GH-FGR-00TE
Posted on Jan 14, 2009
Rayborn
  • 92 Answers
SOURCE: Unlock code on Motorola E815
By default the lock code on CDMA phones is the last 4 digits of the phone number so if you number was
555-555-0909
your lock code will be 0909 unless other wise changed, other than that the only way to get the code is trial and error.
Posted on Jan 23, 2009
I have a Motorola E815 Alltel cell phone and was wondering if I could somehow make this phone compatible with Verizon since they are my current carrier? How do I switch this Alltel E815 to Verizon?
Hi Dawn Lynn Martens,
You can take the device to Verizon to see if they can activate it with their frequency. Since they handle CDMA devices as the Motorola E815.
Best Regards,
Katya
Motorola Support
Aug 16, 2015 | Motorola Mobility e815 for Verizon /...
Unlock code
The phone can be programmed over the air with one step. First, call *228. Once that finishes, call any number and the programming will be complete. The programming menu is accessed from the home screen by quickly pressing "menu", 0, 73887*. At this point, the phone prompts for the Security Code, which is usually 000000 on Verizon, Alltel, and Amp'd, and 236197 on Bell. However, it's possible that this number could be any number at all. Once in the programming menu, the user can manually activate the phone, configure web browser sessions, GPS, Get It Now, and Test Mode. The security code is not the same thing as the SPC (Subsidy Provider Code). Of the carriers that support the e815, only Canadian carrier Bell Mobility uses a subsidy lock code. Verizon, Alltel, and Amp'd do not use SPCs. The SPC is needed to access any of the services located in the aforementioned Programming Menu. There is no default SPC: it varies from phone to phone. The SPC for a Bell Mobility e815 is located in seem 0055, Rec = 1, Bytes = e. The SPC code is usually a 6 digit decimal based number. If this does not work contact your service provider, as they may have to change the simms or unlock it. Good Luck
Jun 12, 2007 | Motorola Mobility E815
Hi, I'm Josef;I have a Motorola Razr cell phone which was originally on a plan with Alltel. I've been told that Verizon bought Alltel, and I'm wondering if sense there is no sim card in the...
If Verizon bought out alltel, the simplest thing to do now is dial 611 for customer care and ask them.
Once a company buys another company, their customer care auto-redirects to the new company. So you can ask them.
I don't have alltel where I'm at (Oregon) so I can't fully answer that.
Thank you
Aug 25, 2011 | Motorola Mobility RAZR V3c Cellular Phone
I have an ALLTEL Motorola E815 cell phone and I want to remove my number because I have a new phone. Alltel doesn't work using sim cards. Help me. Please.
You can go in to the phone settings and restore to factory defaults. This will erase all your personal info.
Please leave good rating, it is important...
Aug 04, 2009 | Motorola Cell Phones
Mp3 driver motorola sliver L7c vista pro
I found these drivers for XP here: http://direct.motorola.com/hellomoto/Common/Drivers%20and%20Plug%20ins/USB_Driver_32.zip
And for Vista drivers, use this address: http://direct.motorola.com/hellomoto/Common/Drivers%20and%20Plug%20ins/USB_Driver_64.zip
Alternatively, you can download and install the USB Drivers from http://developer.motorola.com. These drivers are often newer than the ones above, but you will need to create a user-id first. After logging in with the new user-id, search for "usb driver", or navigate directly to http://developer.motorola.com/docstools/USB_Drivers/Handset_USB_Driver
After downloading and installing the Motorola Driver, you will need to run the Motorola Driver Installer program by going to "Windows->Start->Programs->Motorola Driver Installer->Motorola Driver Installer.exe".
This alternate Motorola USB Driver is required for most phone models from Verizon, Alltel, and US Cellular. Some of these models include:
Alltel V3a, Verizon K1m, Verizon Maxx Ve, Verizon L7c, Verizon W385, Verizon W755, Verizon Razr2 V9m, Verizon V750, Alltel Razr2 V9m, US Cellular Razr2 V9m, Sprint V3m, Sprint K1m. I hope this helps someone. :o)
Jul 03, 2008 | Motorola Cell Phones
Security
i dont think so. check with your service provider. alltel customers can block texts from unwanted senders, but not calls.
Dec 11, 2007 | Motorola Mobility E815
Unlock E815 Motorola cell phone
Try 1234 if it's the 4-digit lock, or 000000 if it's the 6-digit; these are the factory defaults. If your service provider is verizon, then the 4-digit code is the last 4 digits of your phone number. If none of that works, then you're advised to contact your service provider.
Motorola Mobility E815 Logo
60 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
