Question about Samsung SMH7178STD Microwave Oven
Samsung microwave MW1430WA often refuses to respond to any control buttons. Sometimes it shows ''ON'', sometimes ''OFF'' and on these occasions will often restore Time by pressing ''Pause/Cancel'', whereupon the time is restored to screen and normal response to all buttons.
  • Samsung Master
  • 9,098 Answers
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
You have a failing membrane keypad.
On some models, you have to peel off the old one and replace it.
On some models, you remove your controller and move your circuit board into a new frame with a keypad already installed.
FixYa is not currently notifying us when Clarification Requests are answered, so please contact me directly with your full model number from the tag on / in the unit and color so we can help you with free do-it-yourself tips and/or an estimate.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 06, 2009
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Samsung microwave MW1430WA often refuses to
William E. Miller
prototech@usa.net
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
We had a power outage and the display is blinking and there is no response to pressing any button
First, try unplugging the microwave for 2 to 5 minutes and then plugging it back in. Sometimes, a very brief power outage will be sensed by the control as an internal error and the control will lock itself out.
If it continues to blink and does not respond to key presses after this "hard reset", it is likely a portion of the control board could have been damaged from the power outage.
FYI ... the touch panel for this model is no longer available. I mention that because no response from any key press can also denote a shorted key pad.
Apr 15, 2011 | Frigidaire FMT116E1W Microwave Oven
Samsung microwave MW1430WA often refuses to respond to any control buttons. Sometimes it shows ''ON'', sometimes ''OFF'' and on these occasions will often restore Time by pressing ''Pause/Cancel'',...
William E. Miller
prototech@usa.net
Oct 05, 2009 | Samsung Microwave Ovens
My microwave panel is not working.
Sometimes if the door switches are faulty then the touch panel may not respond. There are usually 3 switches, and I'd recommend if one if faulty replacing all of them as a set. Otherwise it may be a Control Panel fault.
Mar 18, 2009 | LG LMVM2055 Convection/Microwave Oven
Keypad for Samsung microwave
To find out about Samsung recalls, please call Samsung's Service Division at 800-932-3837.
Please let us know what you find out so others can benefit.
Aug 20, 2008 | Samsung MW1030WA Microwave Oven
Samsung microwave turns on by itself
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can order Samsung parts here.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
Aug 19, 2008 | Microwave Ovens
My microwave start button doesn't push in to start my microwave
The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
It's most likely that the keypad is worn out or possibly you have a flaky door switch.
We have full details, critical safety, disassembly, and troubleshooting info (as well as door switch testing info) at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually order Samsung parts (either the keypad / membrane switch or control panel with keypad) from http://www.samsungparts.com but that model number is not showing up, so you may have to call or e-mail them through their site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 27, 2007 | Microwave Ovens
Suggestions
check the touch pad or control switches, and check the control panel circuit, check the thermal sensors. check the wiring.
Sep 28, 2007 | Westinghouse WST3504 Microwave Oven
MY MICROWAVE WILL NOT DO ANYTHING
I couldn't find those exact trouble codes, but a common problem is when the controller gets damp, either from steam rising from the cooktop or someone spraying cleaner directly on the keypad. Cleaners should always be sprayed on a soft cloth, then wipe the keypad with the cloth. Also, GE / Samsung codes of F1, F2 and F3 may be the same since Samsung makes GE microwaves. Those would mean trouble with the temperature sensor, keypad, or control panel. Assuming your control panel is clean and dry, it may be time to call for service.
Apr 04, 2007 | Samsung MW1080STA Microwave Oven
Microwave Ovens Logo
109 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
