Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Quit and won't come on again - RCA D52W20 52" Rear Projection HDTV-Ready Television
  • balex9306_be Oct 06, 2009
    I tried checking the tube; not the tube. I unplugged it, disconnected all cables, etc. and let it sit for 30 minutes. Checked to make sure the plug was hot, then plugged it in and sure enough it came back on. Thanks for the information.
    Problem Solver:
  • 3 Answers
On the lower right side on the back there is an access panel for bulb replacement I think it is four screws. Remove to check and see if bulb is blown, the tv runsa a self check and if the bulb is blown it will seem to be not working at all. I have the same unit and it fixed mine. You can find replacement bulbs online and i suggest a longer life one. RCA will charge you about $500.00 for a bulb you can get online for $200.00
Posted on Oct 05, 2009
Yamaha kodiak 1984 runs with choke out a bit ,but once pushed in ,quad quit,s and and won,t start till you pull it out again some
Your carburation is dirty. Remove the carbs, clean, adjust float and re-install. Should be fine.
Jun 30, 2013 | Motorcycles
My tv won't turn on
replace the power supply board @www.shopjimmy .com
Mar 09, 2013 | Televison & Video
Car won't fire
check your fuses as a start then check relays and then fuel pressure because the filter could have only 1000 miles on it and have problems with it and it could also be the coil pack died on it .
Jul 02, 2012 | Hyundai Sonata Cars & Trucks
My nephew kept opening and closing my garage door, now the door won't open with the opener and I can lift it by hand. I tried pulling the cord to move it back to electric but it won't work... any...
The motor has a thermal protector that will cause the motor to quit when it gets hot. If you let it cool off it will automatically reset and should work again.
Jun 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
When I touch the Scan Menu button, and choose scan to computer I get a message that states: No Scan Options I have been scanning for a year. This happened suddenly and I can't figure out why
Hi
Thanks for using FixYa. Due to any reason when the HP Communications process fails the HP Scan application won’t work. To resolve the issue you’ll need to follow the procedure as given below---
  1. Force Quit HP Communications (if running)
  2. Force Quit HP Scan (if running)
  3. Turn the printer off
  4. Turn the printer on
  5. Select Scan Picture from the HP Director application
  6. When the HP Scan application complains, press Reset
  7. HP Scan will then hang, but HP Communications will restart
  8. Force Quit HP Scan (again)
  9. Select Scan Picture from the HP Director application (again)
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 28, 2009 | HP Office Equipment & Supplies
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
326 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
