Question about HP LaserJet 2300 Printer
The printer is transferring ink from the top left of the paper all the way down in line with the rollers. It looks like a smudge but you can see the print. I have cleaned it, but still has the problem. Any suggestions?
    Scholar:
  • 40 Answers
Image problems on laser printers are almost always caused by the toner cartridge or the fuser. If you have already tried a new toner cartridge and that has not fixed the problem you need a new fuser. A fuser that is going bad will cause lines, smudges and ghost images. You can buy it alone or as part of the maintenance kit. www.printerworks.com is a good place for HP parts. Search by model number to see what you need.
Posted on Oct 05, 2009
How do I fix HP LaserJet P1606dn printing issue? it continues to print vertical line/ smudge on the far left of the printed document. Does anyone have any suggestion regarding this issue?
The smudges on the side of the paper is most likely a piece of something rubbing against the paper just after the printer puts the ink on the paper. Inspect as much as possible the path that paper takes. Look at rollers. Anything that grab the paper. Look for ink and dust build up. As for the vertical lines. Could be several things. I you haven't used you printer for awhile the ink in the nozzle could of dried up. Most new printers have a nozzle cleaning function. Try that it a couple of times. See if that helps. If it shows any sign of change after that, it dried up ink. It's a hassle to try to get the ink flowing again. I normally just to replace the cartridges. Let me know if this helps or not.
Aug 05, 2015 | HP LaserJet Pro P1606DN Laser Printer with...
HP LaserJet 4Plus - just changed the fuser and rollers - was getting smudges and shadow on the printer paper. Now getting (on the left 1/4th of the page) light areas with little or no print. The shadow...
Take the toner cartridge out of the printer. Shake it side to side. Reinstall it and print something.
See if that fixes the output.
Could also be the transfer roller.
Jun 28, 2011 | HP LaserJet 4 plus Printer
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
When you print anything, especially pictures, there are black smudges on the paper. They look like roller marks. I performed all the regular maintenance but it continues. If you touch these lines, they...
You may have a bad fuser. The fuser is the part of the printer that burn/melt the toner/ink onto the pager. Check the fuser roller and make sure it lock down and clean.
Jan 02, 2011 | Office Equipment & Supplies
I got smudges when i print ,how can i clean this
It looks like you've managed to get some ink on the rollers. 3 Possible solutions:-
1) Check your printer maintenance menu, there may be a roller cleaning option.
2) Print a document which has printable data on almost all lines, but with empty cartridges. You'd be using a piece of paper more or less as a mop.
3) Final alternative, it getting right into your printer and cleaning it by hand. Printer ink is water soluble so damp cloths/cotton buds should be man enough for the job. The parts you need to concentrate on are the rollers and the small sponge wells underneath where the print cartridges rest.
Apr 13, 2010 | Computers & Internet
Ink smudging off paper
It means that the fuser is not hot enough to bond the toner to the paper. You should open the rear door and see if a paper has wrapped around the fuser roller, as when the temp is actually too cool it will shut down the printer. Photo paper is also too thick to be used in this printer and you should only be using standard bond paper.
Feb 22, 2010 | Minolta magicolor 2400W Laser Printer
Printer is smudging ink on left side of paper
Hello sir; Pull out transfer belt unit replace belt clean blade. it should take care yor problem.
Aug 28, 2009 | Ricoh Aficio CL3500N Laser Printer
Smudge on left side of paper
It seems like your PCU's are dirty and are picking up extra toner. Take them out and look at the green rollers, any extra finger prints or dirt on them? Clean them with a clean paper towel.
Also, check your transfer unit below the PCU's, that may need cleaning or replacing. You can pull that out after removing both PCUs, turn the little screww and look at it. That can also be cleaned with a cleaning wipe or a damp paper towel. There's a little tab that you can turn to free the rollers (they'll still be a little tight) bu then you can turn the rollers to expose more surface area.
Good luck. Be sure to rate the post if it works for you.
Feb 04, 2009 | Ricoh Aficio CL3500N Laser Printer
Verticle line down left side of page
Printers tend to have this problem if for some reason dirt gets trapped under the print heads. A standard head cleaning is the best solution, which can be found in the menu.
Mar 18, 2008 | Lexmark X342n All-In-One Laser Printer
Ink smudge on corner of brochure paper
Ink getting onto the paper when it should not is usually a sign the waste ink tank need cleaning out. Go to www, fixyourownprinter,com for a deeper insight. Also the Canons own Tech Support team
May 31, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP LaserJet 2300 Printer Logo
330 people viewed this question
Seeker5211
Seeker5211
