Question about Microwave Ovens
Turntabable in mircowave is not going round only used couple of time had it for 2years
  • Microwave Ovens Master
  • 9,086 Answers
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can find helpful exploded view diagrams and order parts by entering your full model number here, but if your brand is not listed, try Encompass or call them toll-free at 866-779-5835.
Posted on Oct 06, 2009
I need to know what is the first thing to look at when a mircowave trips a circuit breaker
First off you probably have too many appliances running off the same circuit as your microwave. Try using a different socket. This has happened to me many times at various houses I've lived. For example... My wife uses the hairdryer when I'm warming up some coffee...trips breaker. It basically breaks down to how many circuits your breaker box holds and how powerful it is. Imo Hope this
May 31, 2015 | GE Microwave Ovens
Ge mircowave message is P F
"PF" means that the power has been interrupted, so you need to set the clock, then the oven should work.
If you actually do have a problem with this oven, it will have to be replaced, since GE does not make repair parts available for it.
Jan 16, 2013 | GE Microwave Ovens
Goldstar mircowave model 1310b parts manuel theres a plate at top of cooking area thats is burned two plastic pins hold it to top of mircowave need replacement, help curtis
Assuming that model is MV-1310B, that would be your stirrer fan cover, part number 3301W2A017A, which you can get from Encompass here or by calling toll-free at 866-779-5835.
If you need new clips / rivets for it, they are part number 4051W3A001A.
Jan 09, 2010 | Goldstar Microwave Ovens
Seems like microwave is locked on clock
You have to set a time (any time) to use.
Press CLOCK, press number 2 then 2 then 2 again and then press CLOCK again. Does it say 2:22?
Everything should now work.
Do not run Empty, do not use any metal in there and do not use alot (MW kills all the vitamins and nutrition in food - like eating MUD for your body) .... and don't forget to reset the CLOCK ;-)
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turns itself off after a couple of seconds
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Help, my mircowave
It may have a short, if i were you i wouldn't be using it check to see if your mircowave is on a recall list if its not and your mircowave is under warranty see if you can replace it with a new one
Feb 18, 2008 | Microwave Ovens
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
Microwave
If your handi, most likly you can go to http://www.repairclinic.com and entervthe model number, and get a replacement motor so you can replace it. If your not handi with rlrctrical, you can simply buy an inexpensive wind up turntabe at any super store.
Sep 11, 2006 | Samsung MD800SC Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
