Question about Sony PlayStation Portable (PSP) Console
There is like a black shadow under the screen, my kid says they were rubbing the sceen trying to clean the screen
  • 52 Answers
Your screen is dead you can buy new screen
Posted on Oct 05, 2009
    Scholar:
  • 86 Answers
Well your kids might be telling the truth.They might have,in trying to clean it,pressed to hard on the screen cuasing the pixels to become damaged.Damaged pixels can also result in vibrant colors,usually green,red,or pink.Or your children royaly screwed up your T.V.
My room mate spilled his drink and a little went on the bottom left corner. i dried up as much as possible, but now there is a dark shadow spot on the screen in the bottom left. how do i remove the screen...
liquid is never good on those screens-
there are 3 layers to the screen, from inside out, a fresnel screen (etched circle pattern), a lenticular screen (ridge lines top to bottom), and a protective screen ( "Diamond Shield" tinted plexiglass).
the fluid will wick up btween these layers, turn black, then very very slowly recede leaving a waterline mark. It can take months for it to become un-noticeable.
cleaning is possible, but beware, any type of cleaning fluid or spray is going to simulate the exact same problem but to a larger area.
also introducing dust, lint or hair into the layers when separated is almost impossible to avoid.
these pieces, especially the lenticular screen are extremely fragile nylon plastic and is apt to split under its own weight when handling, so beware the project you are about to get involved in...considering the large size.
but it can be done.
Remove all screws around the screen frame from the back of TV and the lower sides. There will be a wiring harness that goes to front buttons- disconnect it. The whole assembly will come off the front of the TV.
Lay it on the floor face down. Remove the screws in around the inside of the screen. The screens are now ready to lift out, one at a time.
IT IS IMPORTANT to not attempt this by yourself. The screen are fragile and large and scratch so easily which appear as a white opaque area when reassembled. Have a helper. Wear cotton gloves while handling as finger prints will be noticeable after you reassemble.
ALSO IMPORTANT- these screen are oriented front and back...in other words they go together in a certain direction...on each screen layer there is a small sticker on its outer edge. Make note of its orientation and reassemble accordingly.
Clean with a cotton cloth and very very little "plastic glass gleaner" (if needed only!).
WIPE EXTREMELY GENTLY in the direction of the grooves on each screen layer- much like cleaning an old vinyl record.
The lenticular screen is the biggest worry as rubbing on the grooved side is so likely to cause damage. Perhaps rubbing should be avoided if possible.
Let them lay out and dry before reassembling. A bottle of compressed air is good to remove debris when layering them back together...a dust free environment is recommended.
Reassembly and installation is just the reverse of dis assembly- remember the wiring harness connector!
Apr 13, 2011 | Mitsubishi WD-73733 73" HDTV
My Canon Pizma Pro9000 prints photos that contain TOO MUCH black in it. All the colors appear to be much darker than on the screen. And when I lighten the pics, it doesn't help since all the shadows are...
Hi
I suggest you clean it manually by removing the ink cartridge and rub the print head into a paper with alochol and then run the print nozzle for 2 times to clear some ink residue that cause darken color
Mar 08, 2011 | Canon PIXMA Pro9000 Printer
I have a 40 in samsung lcd and i have smudges on the let part of the screen and i have cleaned the surface but it is still there so now what
My son sprayed febreez on my samsung flatscreen and now there is a translucent black wipe mark/shadow under the screen. Is there anything i can do to fix it?
Feb 18, 2010 | Samsung LN32A330 32 in. LCD TV
Blue shadows & black screen with flashing red light
Your problem is the convergence IC's (part number STK392-110). They will need to be replaced as well as matbe a couple of burned resistors that will be right by the IC's. Due to the complexity of this repair as well as the alignment required after the parts are replaced. you may want to contact a tech. Let em know if I can be of further assistance. You can find a local tech by going to the homepage of FIXYA and inputting your zip.
Dec 22, 2008 | Televison & Video
Touch Screen bad on a XL1000
I have posted the answer to this problem if the sceen is misaligned just turn off the machine and hold down the frist to buttons turn the machine back on the singer sceen shows up touch ithe sceen it should freeze and then a small black box should show up touch the box and it should move to a differant spot touch it four times and then rub you finger accross the stright stiche white button at the bottum of the sceen this saves the changes.
Nov 08, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
My Sharp LCD 26" TV shows most black and shadow colours as vivid blue, I have tried resetting the colour to factory reset but that didn't seem to help at all. It occurs on all channels and on 3...
the problem with LCD tvs are that they have back lamps that shine thru the LCD sceen. the job of the screen is to block the light of the different colors to make the picture. the problem is that the very thin screen can not block all the light. if the set has a back lamp setting turn down the back lamps and adjust the brightness control it should help a little. you my notice that the blacks and dark sceens look better when the room is fully lit and look much worse in a darken room.
May 27, 2008 | Sharp Televison & Video
Wet rear projection sceen
You may be able to reach it through taking off the back cover and wiping the screen down. If not you will have to remove the screen assembly.
Jan 20, 2008 | Panasonic PT-53TW54 53" Rear Projection...
Toshiba 52HM95 has black smear in arc shape
defective light engine the light tunnel goes bad...
Oct 19, 2007 | Toshiba 52HM95 52" HDTV Projection...
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
