Question about Federal Industries (CGR3642) Commercial Refrigerator
Looking to buy a condensing fan blade for a federal industries display unit
  • Anonymous Mar 17, 2014
    Federal Industries display Case RSSM678SC to cold cut out at 45 cut in at 82 what to do?
    Top Expert:
  • Federal Indu... Master
  • 12,650 Answers
Go to a heating/plumbing/air-con place or elect supply with unit number or model number off fan-if have old damaged on not better can use to compare for replacement with a universal unit
Posted on Oct 05, 2009
My son has a noisy condenser fan on the carrier condensing unit, model is a BRC060360 and Im puzzled on this unit seer rating, any ideas? Also looking for a budget condenser fan for it?
Condenser fans are usually not very expensive, so I suggest you go to a carrier dealer and buy one as a spare part. Have you check that the fan is clean and none of the blades are damaged.
May 19, 2016 | Carrier Heating & Cooling
Where to buy replacement fan blades
everywhere Christine!
  • replacement fan blades ' eBay www.ebay.ca > Search > replacement fan blades Find great deals on eBay for replacement fan blades and replacement ceiling fan blades. Shop with confidence.
  • Replacement Fan Blades - Plastic & Aluminum Fan Blades ... https://www.grainger.com/category/fan-blades-and-propellers/hvac... Keep air circulating with replacement fan blades and propellers from Grainger. Get what you need to renew or repair broken fans, condensers and air circulators.
  • Amazon.com: replacement fan blades: Tools & Home Improvement www.amazon.com > Search > replacement fan blades Online shopping from a great selection at Tools & Home Improvement Store.
  • Fan Blades & Arms - Ceiling Fan Accessories - Ceiling Fans ... www.homedepot.com > ... > Ceiling Fan Accessories Shop our selection of Fan Blades & Arms in the Lighting & Ceiling Fans Department at The Home Depot.
  • Aluminum Fan Blades - GlobalIndustrial.com www.globalindustrial.com > HVAC/R & Fans Shop for Aluminum Fan Blades in Replacement Fan Blades & Blower Wheels. Global Industrial is a Leading Distributor of HVAC/R & Fans supplies.
  • Aluminum Fan Blades - www.globalindustrial.ca www.globalindustrial.ca/c/hvac/parts/fan-blades Shop for Aluminum Fan Blades in Replacement Fan Blades & Blower Wheels. Global Industrial is a Leading Distributor of HVAC/R & Fans supplies.
  • Replacement Fan Blades - MSCDirect.com www.mscdirect.com > ... > Fans > Fan Accessories & Replacement Blades Discover Fan Accessories & Replacement Blades and other Fans at MSC Industrial Supply. Over 1 million products that ship and deliver fast.
  • ceiling fan blades ' eBay www.ebay.ca > Search > ceiling fan blades Find great deals on eBay for ceiling fan blades and ceiling fan replacement blades. Shop with confidence.
  • Ceiling Fan Blades Replacement - Price Comparison - Canada www.shopbot.ca/ceiling-fan-blades-replacement/price/canada/593664 Ceiling Fan Blades Replacement - Find the Lowest Prices in Canada. Shop Smart with Reviews, Advice and Prices. Shopbot is Canada's Favorite Price Comparison Site!
  • Ceiling Fan Blades ' Replacement Fan Blades ' ATG Stores www.atgstores.com > ... > Fans > Ceiling Fan Parts & Accessories Shop ceiling fan blades & replacement fan blades at ATGStores.com, a Lowe's store. We carry top brands including Monte Carlo, Hunter Fan, & Fanimation.
  • Feb 18, 2016 | Dryers
    How to replace condenser fan blower wheel and where can i get one ?
    Hello, in order to replace the condenser fan you will need to remove the motor aseembly and use a hub puller to remove the fan blade. When removing the fan blade spraynsome wd- 40 on the motor shaft and then attach the hub puller to remove the fan blade. You csn buy the fan blade at any heating and cooling store.
    May 07, 2012 | Continental Heating & Cooling
    Kenmore window unit 17,500 BTU turn on and blows great cold air for 5 min then just fan running after that with no cold air.
    Sorry to hear of your problem.
    This is a common issue, and have just experience the same in my home. I am also an HVACR service tech, and will outline the most common problem that causes this.
    If it blows cold air, your compressor is working fine. For a certain reason your compressor is turning off.
    The compressor needs constant cooling of the motor and its windings. The compressor is also equipped with an overload switch (this turns the compressor off when temperatures inside get too hot). This is probably what is happening in your case.
    The condenser coil (the outside coil that is silver with all the vertical fins) is where heat is rejected. A fan blows air over the condenser to help remove this heat. The condenser needs to be clean at all times.
    First thing - check the condenser for dirt/leaves/cottonwood. If it is dirty, use compressed air, or water to clean the coil, being very careful not to damage or bend the fins, this will impeded operation and cause you to lose cooling capacity. Clean in a vertical motion with the fins.
    If you find the condenser coil is clean, check the condenser fan motor (the blades are usually made of plastic) for broken or damaged blades, and then look into the unit to see if the condenser fan motor runs if in fact the blade is intact.
    I believe if you follow these steps you are either going to find a dirty condenser, or a bad motor/fan blade.
    The only other reason could be a low refrigerant charge not allowing the unit to cool properly, but this can only be verified with refrigeration gauges and a trained service technician, unless you can visually verify oil spotting in the unit, indicating the presence of a leak.
    Jul 12, 2011 | Kenmore 73185 Air Conditioner
    Sometimes get a loud screeching noise from the condenser fan motor. Also seems to be loudr than usual. Motor part no. is:S070. Can a "do it yourself" guy replace the unit?
    If this is wall/window unit, you can do it but it can be tricky. the fan in window units usually has 2
    shafts on either side , it drives fan for both the condenser and evaporator. You basically have to pull the top off, loosen set screw on both blades, remove some screws to move back condenser coil(gently, don't kink tubing) similar process on evap side. Then mount new fan motor, wire it in put fan blades back on in proper position, reassemble unit, test run on bench.
    Jun 26, 2011 | Heating & Cooling
    When the motor starts their is a rattle noise..When I looked in the back I noticed the fan blade had some play in it could that be the problem..
    The shaft of the condenser fan motor will have some play in it, meaing if you are looking at it from the side, along the plane of the fan rotation, it will float to and from the motor itself, or left and right as you look at it from the side. You can isolate the noise by unplugging the refrigerator no less than 5 minutes, a minimum of 5 minutes and for at least 5 minutes. Before you plug the appliance back into the outlet, grab and hold onto the condenser fan blade, it will only be for a few seconds, and the motor is not strong enough that the blade will be ripped out of your hands. If you prefer, you can hold the blades in place by holding a screwdriver in between the blades instead. Plug the unit in, and if you still hear this rattle noise, its the compressor, not the fan motor. If you dont hear the noise, remove the screwdriver between the blades, and listen for the refrigerator noise as the fan motor starts up. If it made the noise then check for any obstructions to the fan blades, check that the three screws that secure the motor are tight, if they are loose, the fan will bounce. if they are tight, you probably have a bad condenser fan motor
    Nov 09, 2010 | Whirlpool (ET1MTKXKQ) Top Freezer...
    I have an Aloha Industries ceiling fan and one of the blades broke on it! How can I get just one blade?
    Unfortunately you can't buy one blade. Blades are made in sets and have to be balanced within a few grams of each other. If you can find the supplier for this brand there is a small chance you may be able to buy a new set of blades but you will need to know the model as well. Blades aren't interchangeable between brands or models.
    Most likely you will need to buy a whole new fan.
    Jul 29, 2010 | Aloha Housewares (93645) Ceiling Fan
    Amana AP148D-RB, Air Conditioner Parts
    Not sure if you have fixed yet, but I had the same problem on my AP148D. There are 2 fans, 1 for the condenser (base of unit) and 1 for the evaporator (top of unit). My condenser fan disintigrated. Go to his web site and you will find a parts list for this model, and a distributer list http://service.haieramerica.com/Models.aspx?CID=231
    Call this number and they have the parts in stock : 800-313-8495, mine shipped overnight. The parts are :
    AC-8000-27 Wheel-blower condenser $21.81
    AC-8000-26 Wheel-blower evaporator $21.81
    I suspect you will need the first part. Hope this helps. Be careful to note where all the screws come from when dismantling !!!!
    Mar 02, 2010 | Heating & Cooling
    PROBLEMS WITH MODEL 59516.731
    - Check if the fan blade is not broken or unbalance fan blade.
    - Check if bolts are tight enough.
    - Check if the fan motor rubber grommet is complete and balance.
    - Check also compressor rubber grommet is complete.
    - Re tight all screws and bolts on the condenser unit.
    - Check the condenser installation if balance.
    Jan 03, 2008 | Dometic Rooftop RV Air Conditioner
    Condenser fan mounting
    Most condenser fan turn ccw looking down into the unit and should be mounted about 1" from motor. A good check is that the air is moving up and out and drawing through the condenser. Thanks
    Aug 08, 2007 | Ruud UAKA030 Air Conditioner
    Federal Industries (CGR3642) Commercial Refrigerator Logo
    95 people viewed this question
    Top Federal Industries Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Are you a Federal Industries Refrigerator Expert? Answer questions, earn points and help others
